Supratad Posted November 7, 2012 Share Posted November 7, 2012 Hi I have the HID type lights and have heard tales of them being self levelling, yet when driving at night on unlit roads, I can safely manage only 40mph on dipped beam. It simply does not light further than 50 yards up the road. Can I manually adjust them and raise them up a bit? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted November 7, 2012 Share Posted November 7, 2012 Is your car lowered? Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 7, 2012 Share Posted November 7, 2012 There is some bolts that you can adjust with a 8 or 10mm spanner. Quote Link to comment Share on other sites More sharing options...
Supratad Posted November 7, 2012 Author Share Posted November 7, 2012 Cars not lowered, as far as a i know. It looks normal. It would have to be lowered at front end more than rear though to have such a short beam spread. If the lights can be adjusted thats great, I can do the garage door set-up. I presumed with self levellers there was no such option. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted November 7, 2012 Share Posted November 7, 2012 the self levellers only keep the beam pointing to a specific point. they drop over time for some reason on the zed, so occasionally need them adjusting back to normal. but to be fair the lights even when right are pretty crap on the zed as standard. the later bixenons were better, but compared to other cars they aren;t the best. Quote Link to comment Share on other sites More sharing options...
leonk Posted November 7, 2012 Share Posted November 7, 2012 Remove the front wheel arch liners and as said above adjusters are located on back of the lights, Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 7, 2012 Share Posted November 7, 2012 I think I'm gonna have to do the same. Jez at Horsham said with my rear ARB on hard it's going to affect the auto leveller at the back. It sure has that's for sure! Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted November 7, 2012 Share Posted November 7, 2012 you could also adjust them without taking the arch out. you could reach an adjust from the top of the light. but that may have just been the pre facelift. Quote Link to comment Share on other sites More sharing options...
Supratad Posted November 7, 2012 Author Share Posted November 7, 2012 Ooh I hope so. I don't mind a bit of spannering but stripping out the arches just to adjust lights is an awkward job. Blooming car designers. Thanks for the pics, they will be a big help. Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 7, 2012 Share Posted November 7, 2012 I was actually reading up on the adjusting from inside the bay with what I believe to be a 8"screw driver? I was going to do it but if its ore face lift its wheel arch liner bending time. What will it take each side five mins. Quote Link to comment Share on other sites More sharing options...
Supratad Posted November 7, 2012 Author Share Posted November 7, 2012 It takes me 5 mins to open the garage door Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted November 8, 2012 Share Posted November 8, 2012 Look here for headlight adjustment, did mine this way and it's a lot better than when I first got the car http://www.350z-tech.com/wiki/index.php?title=Headlight_Adjustment Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 8, 2012 Share Posted November 8, 2012 That's what I found, I'm guessing the same adjustment 'should' be found for the bi-xenons? Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted November 8, 2012 Share Posted November 8, 2012 According to zmanalex, the adjustment is identical for both pre & post facelift The pre facelift and the Bi Xenon adjustment procedure is the same. There are two little toothed wheels on the rear of the lamp that you can reach with a screwdriver from under the bonnet. Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 8, 2012 Share Posted November 8, 2012 I need to adjust mine too they are bloody terrible sometimes. Quote Link to comment Share on other sites More sharing options...
Supratad Posted November 10, 2012 Author Share Posted November 10, 2012 That link must be post facelift then. I adjusted my lights earlier and the toothed wheel is very accessible from the engine bay. Just a normal phillips screwdriver will reach easily. I can see clearly now, I can see all obstacles in my way. Clearly someone at Nissan noticed that home maintenance of this item was easy and thought "Right, put a stop to THAT. Let's make it much,much harder" Quote Link to comment Share on other sites More sharing options...
Neilp Posted November 10, 2012 Share Posted November 10, 2012 I have the facelift and have an adjuster at the top also Quote Link to comment Share on other sites More sharing options...
SteveW Posted November 10, 2012 Share Posted November 10, 2012 Here you go mate, guide I wrote last year http://www.350z-uk.com/index.php?/topic/51852-How-to-adjust-the-throw-of-your-headlights Quote Link to comment Share on other sites More sharing options...
Supratad Posted November 10, 2012 Author Share Posted November 10, 2012 I don't know why people were removing their wheels and arch liners. It must be galling to then realise it could be easily adjusted. Quote Link to comment Share on other sites More sharing options...
scubapics Posted November 11, 2012 Share Posted November 11, 2012 Here you go mate, guide I wrote last year http://www.350z-uk.c...your-headlights That's got to be the filthiest engine bay I have ever seen on a Z! Quote Link to comment Share on other sites More sharing options...
SteveW Posted November 11, 2012 Share Posted November 11, 2012 (edited) Lol,yes it is pretty dirty even worse now there is 12 months more dirt on it....just never have time to clean the car. I'm lucky if I get chance to wash it once a month..... Edited November 11, 2012 by SteveW Quote Link to comment Share on other sites More sharing options...
