Hissing noise
dErZ
  • 4 weeks later...
It is called floor noise - can be improved by sorting out the earth and the power supply. However, ultimately it is normally down to the weakest link in the system, often the OEM amp and cabling. If the pitch changes when you rev the engine then it is definitely the earth. HTH.
