smudgedon Posted October 29, 2012 Share Posted October 29, 2012 Noticed this recently since its been cold, my oil pressure gauge seems to read a lot higher than usual, reaching near the 120 mark when accelerating from cold Is this normal? Quote Link to comment Share on other sites More sharing options...
ewan221 Posted October 29, 2012 Share Posted October 29, 2012 mines higher as well first thing, normal for the cold weather. Does it go down once car warned up ? Quote Link to comment Share on other sites More sharing options...
glrnet Posted October 29, 2012 Share Posted October 29, 2012 Quite normal as the oil viscosity changes with temperature, thicker when colder, should revert to normal when normal running temp is reached though Quote Link to comment Share on other sites More sharing options...
AMT Posted October 29, 2012 Share Posted October 29, 2012 Noticed this aswell! When its cold and jumping on the motorway it will breifly jump up but it should settle Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 29, 2012 Share Posted October 29, 2012 Quite normal as the oil viscosity changes with temperature, thicker when colder, should revert to normal when normal running temp is reached though +1 Quote Link to comment Share on other sites More sharing options...
smudgedon Posted October 30, 2012 Author Share Posted October 30, 2012 Settles down to about 60 when warmed up I guessed it was something to do with the viscosity but was quite alarmed when it neared the 120 mark!! Cheers guys Quote Link to comment Share on other sites More sharing options...
Ebized Posted October 30, 2012 Share Posted October 30, 2012 Given the oil is that much thicker when cold, for the sake of engine longevity avoid hard acceleration and short shift until you see the normal pressure. Quote Link to comment Share on other sites More sharing options...
smudgedon Posted October 30, 2012 Author Share Posted October 30, 2012 Given the oil is that much thicker when cold, for the sake of engine longevity avoid hard acceleration and short shift until you see the normal pressure. Exactly what I was doing Thanks Colin Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted February 18, 2013 Share Posted February 18, 2013 normal pressure being 30? Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 18, 2013 Share Posted February 18, 2013 For me cold 60, warm just a fraction below 30. I always warm the car up before moving. For me I don't even move till the temp needle has moved above the lower cold mark. Will then refrain from revving the engine beyond 3k till my oil pressure is down to 30. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 18, 2013 Share Posted February 18, 2013 Should not be revving the Boll**cks of it when the oil is cold...warm it up first.... Quote Link to comment Share on other sites More sharing options...
cs2000 Posted February 18, 2013 Share Posted February 18, 2013 Should not be revving the Boll**cks of it when the oil is cold...warm it up first.... Yup, i hate the noise that cars make when the oil is cold, you can tell its not happy, bvut as all have said above, oil pressure is fine, aslong as it settles down when its warm Quote Link to comment Share on other sites More sharing options...
Gonzo88 Posted February 18, 2013 Share Posted February 18, 2013 My oil pressure seems to rest between 30-60 once warm, but when I accelerate it shoots up close to 120. I'm pretty new to the zed so not sure what is and isn't expected. Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted February 18, 2013 Share Posted February 18, 2013 sounds on the high side to me. Quote Link to comment Share on other sites More sharing options...
smudgedon Posted February 18, 2013 Author Share Posted February 18, 2013 My oil pressure seems to rest between 30-60 once warm, but when I accelerate it shoots up close to 120. I'm pretty new to the zed so not sure what is and isn't expected. Once warm mine sits at 30 on idle, around 60 on normal driving at just over 90 if driving with some "va va voom" Quote Link to comment Share on other sites More sharing options...
Gonzo88 Posted February 18, 2013 Share Posted February 18, 2013 My oil pressure seems to rest between 30-60 once warm, but when I accelerate it shoots up close to 120. I'm pretty new to the zed so not sure what is and isn't expected. Once warm mine sits at 30 on idle, around 60 on normal driving at just over 90 if driving with some "va va voom" Happy days that sounds all good to me. Panic over! Quote Link to comment Share on other sites More sharing options...
