nissan350z5660 Posted October 24, 2012 Share Posted October 24, 2012 Hi guys got an 02 import and that batterys gone does anyome know were i can get one thanks Quote Link to comment Share on other sites More sharing options...
Arkwright Posted October 24, 2012 Share Posted October 24, 2012 any local motor factor between £50 - £60 Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 24, 2012 Share Posted October 24, 2012 Hi guys got an 02 import and that batterys gone does anyome know were i can get one thanks Online is your best bet TBH as most people dont stock ones for the JDM with the different terminals. If you want to stick with JDM I cant remember what size it was but I changed mine for a uk battery which was a 005L but you need to swap over to UK terminals aswell. Quote Link to comment Share on other sites More sharing options...
nissan350z5660 Posted October 24, 2012 Author Share Posted October 24, 2012 Thanks what power ah should it be as the one in there is 45 i think its wrong ? Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 24, 2012 Share Posted October 24, 2012 Thanks what power ah should it be as the one in there is 45 i think its wrong ? Mine as between 35-45ah Im sure. My new one is nearly double that. I think it was 330cca also. Quote Link to comment Share on other sites More sharing options...
nissan350z5660 Posted October 25, 2012 Author Share Posted October 25, 2012 Thought so ok thanks ill go check it out Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 25, 2012 Share Posted October 25, 2012 i got mine from eurocar prts but just tell them the terminal are the wrong way and they should find the right one Quote Link to comment Share on other sites More sharing options...
rodgeevans Posted October 25, 2012 Share Posted October 25, 2012 (edited) This is what you need http://www.tayna.co....tery-P3204.html also do dry cell if you interested. It isnt just the side of the terminals but the size also is different on imports Edited October 25, 2012 by rodgeevans Quote Link to comment Share on other sites More sharing options...
nissan350z5660 Posted October 26, 2012 Author Share Posted October 26, 2012 Thanks thats great Quote Link to comment Share on other sites More sharing options...
Saxtoo Posted December 10, 2012 Share Posted December 10, 2012 I use a FISCH F068 with 550CCA and 70Ah from these guys http://www.countybatteryservices.co.uk/delivery Also fitted thinner terminal post adapters over the battery posts, but ask the company if they can build a battery for you with the JDM sizes instead. The Nissan USA literature states 550CCA as standard. I once had one of those 330CCA thin batteries fitted and that was a big mistake during winter months. Go big! Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted January 21, 2013 Share Posted January 21, 2013 I bought my last battery from Apex in Bradford who specialise in S13's, S14's & 350Z's and everything to do with the JDM markets. Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 1, 2013 Share Posted May 1, 2013 Hi guys got an 02 import and that batterys gone does anyome know were i can get one thanks Online is your best bet TBH as most people dont stock ones for the JDM with the different terminals. If you want to stick with JDM I cant remember what size it was but I changed mine for a uk battery which was a 005L but you need to swap over to UK terminals aswell. Hey Dblock Quick query any reason why you switched to UK battery? and the 005L the same size as jdm one? Saskhi Quote Link to comment Share on other sites More sharing options...
Dblock Posted May 1, 2013 Share Posted May 1, 2013 Hi guys got an 02 import and that batterys gone does anyome know were i can get one thanks Online is your best bet TBH as most people dont stock ones for the JDM with the different terminals. If you want to stick with JDM I cant remember what size it was but I changed mine for a uk battery which was a 005L but you need to swap over to UK terminals aswell. Hey Dblock Quick query any reason why you switched to UK battery? and the 005L the same size as jdm one? Saskhi I switched because at the time it was being left for short periods of time and it kept dieing. I know the battery was on its way out but it felt like it used to crank over and no more. Also the UK battery was same price as JDM, better availability, bigger much much bigger. My JDM was 330cca and this one is about 5-600cca I'm sure so, The 005L is a UK sized battery. I needed to switch the battery terminals but thats it. Also if the JDM battery lost say 50% of its charge then it would struggle where as now the battery seems to last for ages! Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 4, 2013 Share Posted May 4, 2013 Thanks for the info Dblock, think il get around to changing to Uk battery for peace of mind! Quote Link to comment Share on other sites More sharing options...
