Trackday fun
robzracing
I'm new to Zeds and new to this forum, so be gentle please! :)
2 Mates and I have acquired this 350Z with the intention of having some rear wheel fun at trackdays. We are all fairly seasoned trackday attendees already and have had a variety of track tools between us, from the VAG stable, BMWs and Porsches.
So, a bit of a change for all of us.
The car we have has already been fairly well prepared having been stripped quite heavily, caged, seats and harnesses all done. It also has an FIA cut-off switch, an oil cooler and the ESP has been switched off permanently.
That's all we know so far about the car but I will be pulling it apart over the next few weeks to learn what I can and also continue with various mods and upgrades before we take it for a shakedown at the start of November.
We plan to fit an Accusump first off and bought one on a certain auction site a few days ago which will arrive next week. So I might be picking peoples brains on here when I tackle that job!
Other jobs on the list are sorting out the doors now all the trim has been binned, sorting the floors out, again as the carpet's gone we've got bumps and dips all over the place.
We also need to adapt the drivers seat to take runners, as our heights vary by about 8 inches in total.
And the brakes are gumbling, so that's hopefully an easy fix.
Anyway, that's it for now. I shall post plenty of pics and progress in the coming days and weeks hopefully.
Edited by robzracing
Looks good. I've striped out my 350, caged it, done the bushes and fitted an Accusump + cooler - not competed in it yet, but done quite a few trackdays and its great fun.
Good luck getting the seat adjustable enough - I'm only 5'10" and I'm on the height limit - getting the seat lower with buckets is tricky.
Hope you enjoy yours :)
Edited by Jez
Thanks Jez, I had already seen yours on your website, and I think my mate spoke to someone at your place about the Accusump the other day. "More trouble than they're worth" I think was the phrase! Hopefully not, as we've bought it now and I'm not aware of any other solution without going dry sump. (Maybe you do?)
Don't think I said that and not sure Kyle would have. I've used them in my old 200SX, customer cars and my 350 - they seem to work well.
I'm not aware of anything else, other than dry sump, that does the job. On std road tyres you don't need anything but on semi / slicks I'd probably be a good idea.
Well that's good to know.. Maybe it wasn't you guys that he spoke to then!
We'll definitely be on Semislicks. I've got a well worn set of R888s but all 4 are 225s so I think we're going to try some Yokos AD08s.
And yes I thought the seat might be interesting. It looks like the previous owner had a custom frame made that sits down nice and low but a very long way from the steering wheel. Fine for one of us who's 6'3" but it's a bit too much of a stretch for me at 6' and our other mate is 5' 8" I think, so he's got no chance.
Going to have to fabricate something I'm sure so if you have found any good subframes to start from do let me know!
The whole cage is bolt in with just the receivers welded in. They've done a very nice job of it I have to say but then it cost over £2k I think. My mate's got all the paperwork with the receipt for the cage so I'll have to get back to you on that. It looks like the same people made the seat subframe too as it's all painted the same colour.
I'll get more pics up tomorrow when I take some myself. As you know these were from the add.
we mounted the fire extinguisher in the passenger footwell and have a removeable seat there, we found that when we took passengers out they were kicking the invisible break pedal (fire extinguisher) so we put some checker plate down to stop that, for the driver side we used some non slip material but to be honest it wears so quick a decent pair of race boots are just as good.
drivers seat we removed/rewelded the hump that pokes out of the transmission tunnel to flatten/drop the seat :)
I'm going to have to do that I think.
+1.
Does that hump not serve any purpose then? Is it just for strength?
I think that's going to be the only way to go either way
First update after the first weekend of having the car. After compiling what seems like an ever growing list of jobs I started with the easy bits on the inside.
As the last piece of trim on the center console was in the way a bit and hanging in mid air around the gear lever I decided to do away with it and, after removing the stereo (which with no speakers was as much use as a chocolate fire guard) decided to make a panel and reposition the heater controls along with the hazard switch and also the internal cutoff switch.
In the boot I continued to strip a bit more out removing the rear wiper and aerial and also the tailgate counter weight.
Next job is to remove the whole airbag wiring harness and control unit, although I still don't know whether the passenger airbag has been removed or not. All the others have but as it's behind the dash there's a good chance that it's still there.
Once that's out I need to get the airbag light turned off, so if anyone knows an easy way of doing this (with out using black tape!) I'd be grateful for any input.
Noticed we still have the cupholder tonight. Perfect to hold my coffee in through druids!
So today the car was booked in to have all the discs skimmed and new pads fitted along with some fresh racing brake fluid. According a label on the reservoir it has Motul RB600 in it already which would be fine except I have no idea how long ago it was changed. So better to be safe.
The discs are very pitted from the car standing around a lot out in the open and they are definately not working as well as they should be, but there's plenty of life in the discs still, which is why we decided to have them skimmed rather than replace them at this stage.
Longer term we'll probably go for a floating disc, but we'll get a few track days under our belts first and see what's what.
The car has DS2500 pads on it at the moment which I have used on and off on other cars over the years and have always found to be ok. But I think we might try DS3000s this time and see how they are.
While the cars in the garage the guys are going to stick it on the rolling road to see how it's doing after 60k miles. It'll be interesting to see and also gives us a starting point from which to begin our improvements.
All opinions and recommendations are welcome :)
you can get a resistor for the airbag light but i suspect you might be able to do something with that in the ECU? assume you have taken the yellow airbag ecu out of the car? (worth quite a bit if it hasnt deployed)
Awesome progress, really looking good, you have to take the dash off to get at passenger airbag really, but i had to take dash off to get roll cage in so did it at the same time.
love the cup holder
We used DS2500's, good for 10-15 mins use with the AP's we have on the car but start to suffer after that a bit (currently no brake vents), the DS3000's are better for longer and thats what we shall be using this week/next week
