rob3fiftyz Posted October 20, 2012 Share Posted October 20, 2012 I only have 1 manufacturers key so I acquired two keys from ebay and 2 new transponders and had 2 blades cut. I have tried to pair the keys with my Z without success, did the old in, out, in out shake it all about the ignition barrel nothing happened, did maybe a dozen or more, nothing!! The blades are ok, they turn on the ignition but cannot get the pairing procedure to start. What am I doing wrong? Have I got everything to be able to pair the new keys? Would like full functionality with the DIY key. Have heard of other success with other DIY but am doubting now whether it is possible. Can someone put me out of my misery is it possible or not, or will I have to bite the bullet? Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 20, 2012 Share Posted October 20, 2012 What year is your car and is it an import? Quote Link to comment Share on other sites More sharing options...
leonk Posted October 20, 2012 Share Posted October 20, 2012 I only have 1 manufacturers key so I acquired two keys from ebay and 2 new transponders and had 2 blades cut. I have tried to pair the keys with my Z without success, did the old in, out, in out shake it all about the ignition barrel nothing happened, did maybe a dozen or more, nothing!! The blades are ok, they turn on the ignition but cannot get the pairing procedure to start. What am I doing wrong? Have I got everything to be able to pair the new keys? Would like full functionality with the DIY key. Have heard of other success with other DIY but am doubting now whether it is possible. Can someone put me out of my misery is it possible or not, or will I have to bite the bullet? Don't know if this helps but i got all three keys with mine and a 4 digit pin number. i'm sure someone said you need this if you need a replacement key? i do however stand to be corrected. Quote Link to comment Share on other sites More sharing options...
Sly@Kaizer Motor Posted October 21, 2012 Share Posted October 21, 2012 You need a Nissan dealer or a decent garage with correct computer equipment to code the keys in. There is no way to code the keys without the NATS pin code and the Consult. (or capable aftermarket computer.) 1 Quote Link to comment Share on other sites More sharing options...
rob3fiftyz Posted October 22, 2012 Author Share Posted October 22, 2012 Its an 04 - UK car, thanks all for your responses I think I am going to try to find a sympathetic garage that may be able to use what I already have in a bid to keep expense to a minimum. Quote Link to comment Share on other sites More sharing options...
Siman350z Posted October 26, 2012 Share Posted October 26, 2012 There are 2 DIY methods, a UK and a US version. The US version (which it sounds like you tried) is no good on our cars. If I can find the UK one I will. Quote Link to comment Share on other sites More sharing options...
buster Posted October 27, 2012 Share Posted October 27, 2012 have a look here my friend. http://www.350z-uk.com/index.php?showtopic=16896 Quote Link to comment Share on other sites More sharing options...
hughesy Posted April 5, 2015 Share Posted April 5, 2015 Resurrecting a very old thread I know, but has any firm solution been found in terms of getting new keys aside from going through nissan? I bought my zed on Saturday with just the one key. I know a code is needed, but I seem to have a four digit number on a random piece of paper, five digit code in the back of the owners manual and some 8/9 number code on a card with a nissan logo saying use this if a new key is needed. All very confusing 1 Quote Link to comment Share on other sites More sharing options...
cudaboy Posted December 7, 2016 Share Posted December 7, 2016 im in same boat bought z yest 1 key its 02 reg Quote Link to comment Share on other sites More sharing options...
veeg33 Posted December 7, 2016 Share Posted December 7, 2016 (edited) Yes, but not straight forward. You can get refurb keys from Ebay fully refurb with new blade. (Around £50 each). But you'll still need a good auto locksmiths to cut the blade and duplicate code (from current key) for immobiliser on your zed (around £100 ish). Once that's done, you'll need to follow procedure as pointed out by Buster above (http://www.350z-uk.c...showtopic=16896 ) to program the transponder for lock/unlock (Free) I did all above 2 years ago, however I managed to cut and code my key in Malaysia for £25.00. I go back to Malaysia annually and took a risk of getting it done there with my original key only (No, i did not fly my zed to Malaysia). Not sure it will work at first but for £25.00 it's worth a try.........Fired up first time and no issue hence why i know the method above works, just a bit more expensive in UK. However, few months ago. Whilst i was packing to move to a new house, I've managed to loose the spare key, doh!! Hence I've purchased another key from a breaker this time (Jon@EmperorTuning, a trader here), for £20, a new blade from Ebay for £3.00. Just need to bring it with me on next trip to Malaysia to get it sorted. I'm assuming this will work too. Edited December 7, 2016 by veeg33 Quote Link to comment Share on other sites More sharing options...
cudaboy Posted December 7, 2016 Share Posted December 7, 2016 how easy is it to get it programmed please? im at point of getting remote cat 1 alarm/locking fitted, buy a spare key, see if can get transponder switched off < if can> so both keys work and you relying on alarm for security. Quote Link to comment Share on other sites More sharing options...
KUGT4 Posted August 4, 2017 Share Posted August 4, 2017 Anybody know how to program a transponder key with no buttons? The UK model instructions stage 'press any key' to program the new key - but what if the new key doesn't have any buttons? Quote Link to comment Share on other sites More sharing options...
KUGT4 Posted August 5, 2017 Share Posted August 5, 2017 (edited) Just an idea As the above instructions only cover keys with central locking buttons and the new transponder key I've bought (blade already cut) doesn't have any then thought the following reprogramming method might work. ... Swap the transponder from the current working key (with central locking buttons) to the new key (without buttons) and vice versa Start the programming sequence with the new key (without buttons) assuming the working transponder works with the new key Reprogram the original key (with buttons) as per above instructions to setup the new transponder Anybody tried this? Would have thought just swapping the transponder chips between keys is viable Edited August 6, 2017 by KUGT4 Quote Link to comment Share on other sites More sharing options...
