350Z roadster seat belt is wet
MR350INCHESLONG
One possible explanation is that if it's raining and you open the door the roof design allows quite a bit of water to come straight down into the area where the seat belt would be when it's out. If it was wet and then retracted the damp might well spread through to the rest of the belt. It's as well to remember (where practical) to leather off or otherwise remove surplus water from the roof if you are just about to get in. If you are already in the car and getting out there isn't much you can do about it. Some other convertibles have mini gutters sewn into the edging to minimise this problem or are designed in such a way that the rain runs further outwards. You also need to check the seals to make sure water isn't getting in even when the door is shut.
Hi ya
A fellow Z d and I have had the problem of rain getting in under the back seal below the back window . Have to have the roof half open or closed to see water lying inside. Local nissan garage cant come up with any answers for this. Lookin for answers myself.
Best Regards Steve
