HORIZONTAL tonneau cover
Tinyflier
I've acquired a horizontal tonneau that sits between rear strut brace and rear hatch that hides anything in the rear portion of the luggage compartment from prying eyes.
The cover has two tabs that slip into slots on the inner hatch cover and two "screws" that slide into holes on the hatch cover and should secure tight.
Problem I have is these outer "screws" don't seem to be engaging with anything inside the hole, hence the cover slips out as it is only located using the tabs and slots.
Anyone had similar issue and worked out what these screws are actually trying to locate into?
David
In case anyone is remotely interested in the solution...
The fixing "screws" are actually a press fit - and I think are one time fitting only.
Tonneau fitted and my rear boot area is now hidden from sight.
David
Edited by Tinyflier
