dErZ Posted October 18, 2012 Share Posted October 18, 2012 I've had an odd issue where when I drop my roof (windows automatically go down) then the drivers window won't go back up on the button(passengers one is fine). I have to slam the door a couple of times and then it'll work. How can I test the switch? If that's fine then ill give this a go http://my350z.com/forum/maintenance-and-repair/459628-window-motor-repair-they-can-be-fixed-2.html I've purchased the bushes just need to grow some balls and fit them... Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted October 18, 2012 Share Posted October 18, 2012 Cant say I experienced this problem on my roadster, but the motors are known for being a bit week - im guessing gravity is helping on the way down and not enough grunt to get it back up again. Check the connections and switch first though, like you mention as it will save you some hassle if its just a dodgy wire! Quote Link to comment Share on other sites More sharing options...
