Scream if you want to go faster!
evilscorp
So the brakes are done, but no chance of testing them so the review will have to wait. Only a few burdens with the kit;
1. it has a few washers/spacers which are fidily to keep in place when bolting up the caliper bracket to the hub.
2. the brake hoses are not as easy to attach as the hel items I had previously, you need to rotate the whole hose which is a bit annoying if you have left a drip tray on the ground and it keeps hitting it out the way :lol:
3. the bracket for keeping the hoses free from hitting suspension parts is not the easiest or obvious where to place it. ?? still not sure if I like the idea of the BC suspension bracket and the hose is slightly shorter so wont work with the hel bracket.
Apart from those tiny gripes it is a decent kit to fit.
22448104_10159488166005441_8293803016025
These were totally caked in @*!#, needed a proper clean to get the little fork spring retainer out.
22449871_10159488165980441_7437481086821
22365627_10159488165985441_3279814859911
22489645_10159488165880441_2204240842621
Stupidly I did a rookie mistake, in my wisdom I thought it would be wise to crack/check all the nipples would open, then tighten them back up again.... bar one.
This led to air being brought into the system for ages until I realized why the bubbles were moving too fast and not properly creating a vacuum :rant:
Might need to buy another brake fluid as the level is low, doh!
Bottom red stripe added for breaking up the murdered out look.
22688776_10159541186180441_389457884447622780612_10159541186190441_4102765853277
I hate the prep work:dry:
22728943_10159541186175441_6338067002892
Also bought a cheap set of areocatches, not sure if i will fit them to the z or the koukicuda, the locking mechanism looks rife for corrosion issues, so I may splash out on a real set and compare the two.
22730096_10159541186165441_6745132168185
So the difference in catches is small but the quality of the real item is obviously better. The fake will go on the koukicuda. As the lock is suspect (check the gap). Also no fixing plate underneath which will need something fab'd up rather than tiny washers.
23032680_10159580420085441_1607631958533
23132074_10159580431795441_6207219809724
Filled in some rivet holes that weren't used on the stardast kit so it looks a bit better and less like a bodge together of kits.
23131596_10159580419945441_8617093640850
prep for spraying.
23231338_10159580419980441_2697370553360
23031714_10159580419975441_8596446305337
and then I sprayed.... might have ****ed up a skirt, tried a different method of spraying on a table rather than hanging everything like i did before, it wasn't as good/easy then my light broke so I wasn't able to see how much paint was overlapping.
Doh.
Waiting for the morning to try again on the other panels.
  • 3 weeks later...
So cutting into a carbon bonnet is up there in my top 5 bum squeeky moments. So many minor adjustments needed to make this dam thing fit, slight bend of the pin, slight elongation of the radiator support hole for said pin, lots of cutting of fiberglass and carbon. just need to cut a rubber gasket so water isn't as much of an issue (bonnet has vents so who am I kidding.)
messy business.
it will sit flush.
Wheels and tyres are on....... looks @*!# hot in the flesh.... from far enough away from the paintwork.
ride height will settle a little lower but need to keep it high so I can get in and out my driveway (even with wooden boards). But the tyres should have added 7-10mm extra height.
So will it pass an MOT? Or do I need more camber? 4 wheel alignment next.
Battery is off the trickle charger, just a few more bits and my poison will be outside! in the fresh freezing cold winter lol.
  • Like 2
1 hour ago, valy said:
nice :thumbs:, finally getting close to the finished article....wheels look sweettttt now that they are on the car
get that front mesh changed and it will look even better
well done :D
I've yet to find some i like =/ been searching ebay with no luck, there are some nice ones in plastic but it probably isn't flexable enough to work.
https://www.ebay.co.uk/itm/Universal-Black-ABS-Plastic-Racing-Race-Honeycomb-Mesh-Grill-Spoiler-Bumper-Vent-/141794307446?_trksid=p2385738.m4383.l4275.c10
Edited by evilscorp
6 hours ago, Keyser said:
Coming along very nicely indeed :thumbs:
Thanks bud, seems to take me days just to do tiny jobs when I look at your tinkering and the amount of cars you have finished and moved onto I feel a bit lost and out my depth lol.
Edited by evilscorp
Everything takes longer than you think, I've spent all evening making 1 little connector and I'm only half way through - Just keep at it it will look great when it's done and you did it -  mega bonus :thumbs:
Well you didn't miss much:lol: she made it to the end of the street then had to turn back, couple of interference issues with tyres and bodywork:blush:
The wheel arch liner for the passenger side needs some cable ties to hold the two sections together as the front seems to have curved down and is touching the wheel on bumps.
But the main issue is the larger tyres hit part of the ams superlagerra wings so the cutting disc needs to come out again, no biggie.
She sounds good, and can't hear any leaks (you guy's with vortechs will know i am talking pish as you can't hear much over the jet engine lol).
Still need to attach the zspeed undertray properly again and sadly maybe have to raise the ride height a smidge.
2 hours ago, The Chubby Ninja said:
That mesh actually looks pretty good! It's soo hard to get mesh that doesn't look chavy. Can't be far away now tho man :)
Yeah it's not easy to find nice stuff, took a punt and happy with it so waiting on two more sheets to come, one for the side vents and the other one for the koukicuda headlight grill.
I could probably have it on the road next week, just have to wait for the mesh then a slot with my friendly MOT man.
Won't be driving it much but plan to give her a wash and take a few photos before going under a car cover while I start work on the other car.
  • 1 month later...
Just had a P1065 code for ecm issues thrown up, also a running rich one which is fine as the car was sitting idling on a hill for a while.
Think I read somewhere if you mess about with the side repeaters it happens, which would explain it as I was having to rewire one as I couldn't be assed disconnecting the battery.
Codes are gone now so hopefully all is ok for MOT tomorrow!
