Scream if you want to go faster!
evilscorp
Hi Rob, no there shouldn't be any clearance issues with the head casting like you get on some of the high lift cams which need metal removed for the lobes to spin freely. As for piston to valve clearance, this will be reduced due to the 2mm? (Need to check) increased opening, but this is more a case of timing setup rather than larger reliefs being cut in the tops of the pistons
It's still always advisable to check clearance once assembled. Best way is to only put the main timing chain on and one sprocket(think it's the exhaust) and only that cam, then you can move it one tooth forward from its normal timing Mark to account for valve timing changes.
The JWT C9 cams need milling of the head, so any other cams that are that extreme would also need work.
It's coming along good gary and the garage looks awesome! I'm just doing nismo valve springs and relaping the valves in on my heads. Wanted cams but the budget wouldn't allow it after my gearbox and clutch went at the same time as the engine :( hopefully do them next winter if I'm not swapping the supercharger for a turbo :)
Thanks Stevie, Yeah I would have reused my valves but one of the heads has been detonating and the spare head (which i ain't using) had damaged valves so I imagine the head i am using has weak valves so better to replace, cam's just kinda happened, didn't plan on them but since my engine wont be ready for japfest i had the machine shop money laying about :lol: and some extra overtime at work changed the plan.
Just use a brass wire wheel to clean up the valve seats and valves and then use the lapping tool and paste and you should be good to go!
The rough casters left some material so the plan tomorrow is move it to my dads garage and then start the prep for the self leveling compound. Brush all the dust out, wash the floor with some cleaner then mask off the edges and stick cardboard down the pit cover and front door to stop it from leaking out. Hope to have the family ready to pour it on sunday morning then a few days to harden and then finally THE Z WILL BE HOME! :yahoo:
(then kicked out again after japfest so I can lay the fancy resin floor :blush: )
Just for future bud, I've got 2 spare heads there if you are needing one. How were you getting det? Lucky it didn't go bang lol. My mate is going to come over and show me how to lap the valves in as I've never done anything like that before, and agra have already cleaned the valves when the head was being skimmed so that saves a job :) got valve stem oil seals and nismo valve springs to do aswell even tho I said I wouldn't touch the heads lol
I've never had det but the spare engine i bought off ebay had it bad :scare: one of the valves had a chunk broken off it and the top of that cylinder got a bit banged up so I ended getting a spare head from Alex, but i don't trust putting valves back in if they have been exposed to det. Also they are caked in crud and couldn't be arsed cleaning them :lol:
So that went well......
16997691_10158378089345441_2625638247743905127_n.jpg?oh=904cf847daeb21ac5fb35b5574fad1f2&oe=5971F51E
17190595_10158378089360441_24861607174336683_n.jpg?oh=04d65de8183ebd8ef6f316c1cc129419&oe=596CB8BC
16996053_10158378089340441_6560266032743136238_n.jpg?oh=7c99b14d4f615a9cd133e5423b81eaa2&oe=596B8D19
16938572_10158378089350441_3778972605595722253_n.jpg?oh=de60eaf310f6cd3b4a1fa64f10bc7c57&oe=592C9F59
shame that my dads drill packed in :blush:
need to wait till next weekend when I can have some helpers again as this stuff sets quick and the spiked shoes arn't the best for running about in.
Tomorrow should show if its worked and if I should carry on and do the rest + maybe another thin layer ontop of the stuff already poured.
  • Like 2
So I have given up with the floor to get the car ready for japfest also it hasn't 100% worked so need to see if some of it has bonded properly with the floor (lack of SBR or PVA prior was probably the issue.)
Finally though I have somewhere it is a pleasure to work and the lack of any swear words being used is magic!! So good having a nice warm dry space to work with plenty of room.
17309120_10158420858405441_5010297485299148311_n.jpg?oh=894905a927170f13f075237edbb8a5e8&oe=595E88DB
car in and work ready to begin!
17309271_10158420858330441_4152390215337330319_n.jpg?oh=e48aacebd7231995296eee79ee34359b&oe=595CE793
new battery terminals needed as jdm connectors are smaller :dry: but they were knackered anyway.
17308902_10158420858260441_1099482566900933302_n.jpg?oh=54dc2219ea6a8088ce058abc2abc6a41&oe=5930B5DE
rubber gasket to act as a spacer/shock absorber between the sideskirts and fenders.
17203163_10158420858285441_6505822370010466256_n.jpg?oh=58e8f95b3623198e8012b8a144fa5abd&oe=592CE057
17264864_10158420858230441_5067293375819346950_n.jpg?oh=cb2185a52e7a6735dd20f34c1a224e1f&oe=5932A4FB
the wrap should cover them to help blend in better.
17309318_10158420858085441_8146694652625306079_n.jpg?oh=64044e5e0fcdb8719a1f26b0a2b6e085&oe=592B980B
Errrrmmm not sure i used the correct screws, had a few spare.
Not ideal doing so many jobs ages ago as i kinda forgot where they all go :lol:
17264324_10158420857970441_4305591112705246173_n.jpg?oh=27ba6cf464f5a4a3878e62446f2967c7&oe=59652C50
other door card finally on.
17264788_10158420858145441_4501673186838981754_n.jpg?oh=7e6e7a6a02d63470f41d66a28cb0339c&oe=596DC46C
bumper off for light wiring fixes and boot release bracket fabrication + diffuser.
17309336_10158420858075441_85392793097790745_n.jpg?oh=d491c029b140eae6a0b2af165c1b033c&oe=5973150E
soon to be stripped bare. :teeth:
Fiberglass work to repair damage I done and areas I wasn't happy with, need to use filler next.
17424982_10158473012645441_4890293149502915931_n.jpg?oh=60fda2ae6e400005de2bfdb20745e256&oe=5963215A
17426357_10158473012830441_978636071586353246_n.jpg?oh=611da88dc676771b01b3af294e3869ef&oe=5955B0D1
17458108_10158473012245441_1373827728311702976_n.jpg?oh=9ae7a5e156e10593415e0aa8263616de&oe=5971B5FF
a bracket for wheel arch liners on the new fenders.
17425068_10158473012825441_675775772881801885_n.jpg?oh=c8b5dc627a8135b78536a5676ead3d2d&oe=5950E344
17457332_10158473012305441_8895837194929062211_n.jpg?oh=0d7a176e2b3f5c767d4894c7fe113ee7&oe=5952A5FF
masking up the rear arches, plan to make a cut along the middle of the bottom curve and bend inwards and rivet together until I get welding gear.
17425914_10158473012205441_1194029035165433689_n.jpg?oh=55b7f497fe643bc36f0241597dfdd158&oe=596EDE31
17342720_10158473012270441_5902755390183757176_n.jpg?oh=d87f6853a1f57464e48db07b44007f11&oe=5951A2DA
17309452_10158473012700441_7607647696242041584_n.jpg?oh=3b18f65a736646b308d8896f9e06c6dc&oe=5952C4C7
This was the most scary thing I have done to the car. :scare:
17553582_10158495860285441_1684163944305884123_n.jpg?oh=464265383797dc2661c809bcc6c80b12&oe=5954D877
17498423_10158495859570441_1563301006284584244_n.jpg?oh=3e34c51ed4233deb8ac9b324e6e17252&oe=59503EE0
17553751_10158495860595441_1242125778168212614_n.jpg?oh=c6c55a9412deee9db240ae9aff2bb2e8&oe=596BE553
17499571_10158495860600441_835285352300670516_n.jpg?oh=92dae7cebac1402185737b0541a9fcc2&oe=595046BF
plenty of krust used to kill the tin worm. not sure how far I plan to bend the arches up yet... but I will lay some fiberglass over and under the flaps to make a new wheel arch liner for protecting the underside of the expensive stardast kit. Then filler and finally underseal the bottom to keep the rust away.
17626412_10158495860330441_8215623984920647266_n.jpg?oh=21d417d50ccb0e4aadd53a0ba5b56596&oe=5951E589
finally new battery terminals. Also picked up my new double din head unit which I will fit tomorrow if i can fit it in.
17523658_10158495859580441_556351633108952788_n.jpg?oh=071202500772329f8e2a464582a161de&oe=5961AE1D
the last tangs before filler and paint.
Yet again I start one job and jump on two others.
17553542_10158500980250441_1928414229902373453_n.jpg?oh=95c2f8e81fdb6eecd8e0cd49f9a922d0&oe=595B7F34
17554459_10158500980665441_2087296278824634020_n.jpg?oh=0bb6ec7552612f43acd640950a6e0e44&oe=5963E4B3
17629831_10158500980640441_4995221316353864175_n.jpg?oh=9a00880d395bc2f2d284056055c65181&oe=595360CE
so that plastic thing was hiding half my garden in it.
17498855_10158500980510441_6890245980859387517_n.jpg?oh=1304845f164c6dd91609e129dfc3e634&oe=595CEA63
17458076_10158500980340441_4450655010855959919_n.jpg?oh=d3192d19eb4772f3d474b9ed1b9e960b&oe=599982E2
17457755_10158500980495441_8338612549635810913_n.jpg?oh=b16443d3776c2d1d2d68998b6903fc6f&oe=5960C172
fiberglass didn't work, too uneven and hard a surface to attach to, had a layer on top and on the bottom but they kept falling off and wouldnt stick flush so.... its bondo! time aka filler and fill in the rest of the tangs with rivets.
17630053_10158500980525441_3516456190544920097_n.jpg?oh=c80541bae2546ddd6c1587dd8db178a3&oe=59667B52
what the hell is this, not that it is in the car anymore.
17553841_10158500980290441_9140416345290007715_n.jpg?oh=359ea401719453f1bde3fd2f6c9a2d4d&oe=59994E2D
started to fit the new stereo and ended up ripping out an microphone to attach a new one :blush:
wired up the gps receiver, then noticed the old wires for the jdm sat nav............... :wacko:
I might have got carried away and ripped out the rear amp and the wiring loom on the passenger side and the antenna cable which I need to replace for a simpler one.
17553893_10158500980385441_7370739949256348126_n.jpg?oh=297a5494b055959357544ac60d04b00a&oe=5953E51D
17523660_10158500980560441_4180950443326449371_n.jpg?oh=8043a513717e32575f20fba4d55e4e35&oe=59543843
