Scream if you want to go faster!
evilscorp
  • 3 weeks later...
Something like 19 hours on these heads so far :headhurt: for porting and polishing, if i was to use a metal bur it would have been quicker but I am new to this so taking it slow and steady.
This also turned up, 15800450_10158090745010441_2194910446513591650_o_zpsgzp6yevp.jpg
I will eventually hire it out for people who need to rebore their engines and try to recoup some of its cost as it wasn't cheap :surrender:
Also the missus asked for a cup holder but the oem audi ones retail at £140 :scare: so i made her this for £4. lol
Tried to tap a thread into my spare cylinder head's valve guides but it was not tight enough and the threads of the bolt wont catch, the next tap size up is a lot larger and will be difficult. Hopefully I will try again on a valve stem that is in better shape as that was the worst one and probably very worn.
I am also in talks with a wheel shop about vossen work vws 1 or 2's for my wheels, as the hre wheels i wanted are out of my budget.
Few other things taking up my time like the missus tt diff is making noises and i expect its in dier need of an oil change (life time oil my ass!) but the hex fill plug is seized solid and has started to round :rant: hammer and chisel tomorrow.
  • Like 2
HR head gasket block mod done today, and more boring head polishing.
15894897_10158109107270441_3066170459436692915_n.jpg?oh=bd6638e30d6beae35488749172214646&oe=58E26785
The mini sand paper rolls were 12mm which is what you need to remove downwards from the original casting. mine worked out about 1inch below the deck surface so used that measurement when I switched out to the faster bur on the big drill.
15972494_10158109106945441_3100366791394779756_o.jpg?oh=35a47e6650a5a3572408d35c7bcf151b&oe=59157224
15896285_10158109106705441_7532582547368848615_o.jpg?oh=ce02058d68978c40fdc0e9c1bf430b85&oe=592300F4
15994978_10158109106310441_529807005575804321_o.jpg?oh=5b7384525710861f9926efffcdcfbb0d&oe=58D693F6
15894873_10158109105895441_6162032539149921755_n.jpg?oh=971de966db46547dc898d0a3aaf8b47a&oe=5910938B
15994553_10158109105490441_6467183011843405168_o.jpg?oh=d4c3b6155d39e5e08b904ed64e06b3ea&oe=59155823
15894633_10158109105140441_6593804872186684739_n.jpg?oh=3ed112bc3f414558d42f77b627b6261f&oe=5911A983
15965804_10158109104765441_5899845818467433701_n.jpg?oh=b52fb42d07fde0a758d073b4d877049e&oe=5920BDF3
15894971_10158109104405441_5444185568660363496_n.jpg?oh=bdd4a512946b5f0f852eb5357b63c4d3&oe=5921EC87
15894382_10158109104075441_771757962613049693_n.jpg?oh=6cce28f5405e0e3efed1dfb01e790062&oe=5917FA6C
16174409_10158150500280441_6720785572492874082_n.jpg?oh=99976759a5aef6b2dc493388e01eda26&oe=5903D727
removing valve guides, 1/4" UNF tap and bolt used (M6 is too small and M8 is too big, you try finding M7 s#@t!)
Then used a 7.5mm drill through from the deck side to thin out the valve guide and reduce its interference force on the cylinder head.
Good old hammer and a punch, (dont use a valve especially a broken one that has been work hardened :blush: )
Not much effort involved to remove the old guide but I plan on heating the good heads in the oven at 70-90* to allow them to come out even easier, no scoring of the bores :D
16178596_10158150499705441_8339103207711002739_o.jpg?oh=b4ee8ae9962e0fd049f04f25eb8e8c8e&oe=591D46EB
16178833_10158150499435441_957396559121093507_o.jpg?oh=a81c07c02ccc8f13ddd31457912334c6&oe=591F1D21
16143256_10158150499190441_5749215905816697283_n.jpg?oh=414aaa4f95a2611d3c5f404478501239&oe=5903332D
16113898_10158150498755441_9151846508329472593_n.jpg?oh=3b4284b8310389f7b843bf57a7a19705&oe=5923FBDF
16143008_10158150498595441_3599223046031722203_n.jpg?oh=eddb13ee87757040faa11a8c46d074ab&oe=5919596C
16143529_10158150498385441_4074519989977197454_o.jpg?oh=262d07224ac6180388a13cc82bc30c98&oe=590756B2
Woohoo! Great timing from Torqen, new valve guides and other hard to get ferrea stuff at the best price.
Just need to get my finger out now and grow some balls, enough practice on the spare head.... well i might do another few guides before i am confident i wont drill wonky and go through the side of the guide and knacker the bore! :lol:
Now Adrian about those fancy wheels........ :teeth:
Bum... just checked the price of a bench drill.... the accuracy is needed and the price is low enough. Any recommendations for a cheap £100 bench drill? :lol: Takes the fear out of drilling straight down the valve guide.
Edited by evilscorp
  • 3 weeks later...
So the garage is coming along, but no show again from the builders today :dry:
Thinking about the two part resin flooring with flakes through it? whats everyone's opinion on garage flooring?
16684385_10158257350275441_5982654433286448711_n.jpg?oh=06871e5235693cdb0d717dd04705acb5&oe=594638E2
Took the valves springs,keepers,etc out of the head zmanalex sent me, only issue is my cheap valve stem seal puller wont budge these ones so will have to use pliers.
16602907_10158257350385441_8631273335804425230_n.jpg?oh=8e54289d877d6c813a2e20af0b9f18cb&oe=594980B0
Could do with a good clean, plan to reuse the keepers and retainers so have coated them in oil until I can be bothered giving everything a clean (in the new garage).
16508882_10158257350345441_9038736885429126712_n.jpg?oh=1b0cee2da8dc81e9a42e6b0c0c2f1676&oe=590213E4
New stuff from torqen, but need to wait as there was a minor mix up and I need to switch valves and have also ordered some JWT C2 cams (in for a penny and all!)
16640891_10158257350195441_5209638510964628435_n.jpg?oh=f18eb5435875e680e8bc1fbe5caeaac4&oe=59372F63
Also bought this so I can be 99% sure everything will be torqued correctly as my old mechanical one has been laying about for a few years and would prefer to have a back up.
16487803_10158257372440441_6097086429929459592_o.jpg?oh=ab5f91c3163dca0c84b80a4482f1f209&oe=5947CB3A
Wheels have also been ordered :stir:
so which ones did you go for in the end ? :scare: ...also what is the delivery frame and what size ...
16807482_10158314177795441_5014703091450921618_n.jpg?oh=337ea7ac86f139401f777d8868196250&oe=59404199
16832013_10158314177920441_4143821890492564747_n.jpg?oh=e94004e15130f38708d186bf3d8a77f4&oe=592FC5E6
started to prime the walls for paint with some stuff for sealing concrete blocks outside so should do the trick for inside too, then a few coats or one thick coat of white emulsion paint, nothing fancy for the walls as they are for light reflection mostly and will have some hangers/shelves and tool boards attached soon.
16649493_10158314177915441_8347378308710783487_n.jpg?oh=a7cb1e0e052d0a97fc09a61f8d806c0a&oe=59444460
16807756_10158314177905441_9111188255934885657_n.jpg?oh=0e745f2c8f6e34019e0c30d2f1fada4c&oe=58FD777B
Just waiting on the outside smooth casting to be finished and the pit cover being made. The builder also said he was hiring a grinder to smooth the floor, not that bothered as I have ordered 11bags of Cempolay Ultra Levelling Compound, a spiky roller and some weird spike shoes to help apply the stuff. Then it will hopefully get a coat of this
or what I really want :lol:
  • Like 5
Not as good as yours, also looked through your build thread (as usual before i tackle any job) and realized i could have probably installed a floor lift like yourself but set the max height so the car was just clear of the roof :blush:
You have a pit so that's great, you can get those portable half height scissor lifts for one side if ya fancied and funds allowed :thumbs:
Well the emulsion paint didn't dry :dry: I think its the sealant my dad gave me that is the issue so I have bought some PVA to try on the rest of the walls and see how the paint drys with that as a primer.
Also bought this
Should help cut down the time to primer the bodykit before wrapping.
