Scream if you want to go faster!
evilscorp
DIY guide of what not to do.... probably.
Bought the car summer 2010 stayed standard 2 weeks then zeditus struck. I dont eat or buy new clothes, my shoes have holes in them my girlfriend moved to Singapore for a year as my other "woman" has taken over. Life sucks :-D
JDM 2003 track spec or whatever crazy option list they ticked.
brembos and lsd all I cared about.
BODYWORK
ing+1 full bodykit with poo paint job(one of two things I did not fit myself) Now with oem bumper GT lip and carbon canards
seibon VS carbon bonnet with fiberglass reinforcement removed in areas to allow raisd strut bar to fit.
zspeed undertray
Stubby arial
Drift crash bar
Carbon ebay eyelids,.
WHEELS
rota 19"grids in black
245/275 falken 452 tyres
SUSPENSION
BC br series
new bushes and bolts for some of the hubs.
Eibach roll bars
Whiteline drop links
whiteline diff and subframe bushes
whiteline rear axle bushes
eibach camber arms
SPL traction arms
BRAKES
DBA disc's all round
ebc yellows or ferrodo's trying them both out.
Hel gold lines to match the brembo calipers and BC's
(hopefully you have scrolled down to miss all the boring stuff)
ENGINE
DC Sports true dual
AMS lightweight pulleys
motordyne plenum spacer
platinum one step colder plugs
Uprev
AEM wideband air/fuel gauge
AEM boost gauge
AAM basic fuel return system
Deatchwerks 600cc injectors
walbro 255 fuel pump
Uprev GT MAF
Rutland motors catch tanks
Vortech V3 supercharger
3.12 vortech pulley
Timrod radius rod
3" Maf intake pipe
Treadstone 1245 intercooler
K&N big boy filter with Ash hoses for custom intake.
Kaaz 1.5 LSD
ICE
some head unit that adds weight, probably with one or two speakers in the rear.
INTERIOR
fire extinguisher
boot plastics removed
me
COMING SOON
Competition Clutch Stage 4, 6 puck sprung
Lightweight flywheel
BGW
Stardast + AMS front frenders and side skirts + JP vizage bumper and JDM rear with diffuser and smoked LED indicators
Ditch finders tyre lettering.
Red wheel nuts.
Alcantara and diamond padded leather doors.
SFL oil gauge in tarmac sports twin a pillar pod.
New wheels!
Built Motor;
Eagle rods
ACL bearings
ARP main studs
ARP L19 head bolts
Rev-up oil pump
Wisco custom Pistons 9.5;1 with coatings
Head gasket Cometic
Fluidampr crank pulley
Mishimoto hoses
Mishimoto radiator
Mishimoto fans
Mishimoto 1.3 bar carbon rad cap
Mishimoto oil sandwich plate
DC sports headers
Nismo thermostat
HKS twin spark
RC 1000cc injectors
Areomotive 340lph fuel pump
GReedy magnetic sump plug
Nismo balanced crankshaft.
Haltech platinum pro plugin ECU.
Jim Wolf Tech valve springs.
Kinetics Plenum (Modified by zmanalex)
Valve stem seals and new valve guides Ferrea
Water pump oem
Timing chain and guides oem
CJM fuel pump -6an adapter
Brian Crower intake/exhaust valves
JWT C2 camshafts
Probably other stuff I have forgotten about that has been thrown in the attic with the rest.
Here is my car parked in glasgow
Edited by evilscorp
  • Like 7
  • Haha 1
Started to install my AEM air/fuel gauge but ran out of time, will finish at the weekend.
Surprising how long it takes to poke a hole through a rubber gromet using long nose pliers! Also kept changing my mind where I wanted to route the cable, and since the seibon bonnet lets in water at the back I desided not to ruin the main gromet that is used for the engine wires and use the one at the front of the battery bay, just need to cable tie it round to the back then drop it down to the tranny (hehe) bracket that the original O2 sensors are hung off.IMG_20121025_121122.jpgIMG_20121025_121622.jpg
Its just hanging at the passenger footwell at the moment until I remove the centre console.
Best route to run them :thumbs:
Are you planning on running 2 or just the 1?
At the moment just 1, the hdev decats only came with one spare bung for some reason, also not sure how gd condition the thread is in. I have two spare but dont want the hassle of removing the decats when i dont have access to a ramp.
Also going to try and mount the gauges where the jdm satnav/rear camera screen is,but not sure if i will have space for three in there(boost and the A/F gauges).
Edited by evilscorp
Installed the O2 sensor and routed the wires up the original wiring loom and along the brake line and into the battery compartment.
It was all going smoothly and was happy with the placement of everything, went to wire up the power to the gauge and ....... nothing nowt zip!
Reconnected the tv screen that used the power wires and it worked fine, so ruled them out, then Keyser recommended I try the gauge directly against the battery and nowt!
So it is either a poor join in the supplied cables or the gauge is jiggered! waiting to test the cables on monday at work with a multimeter.
Then had a go at cutting out a alu plate to fill the hole and mount the gauges in.
So after Keyser spotted I had been sent the wrong instructions, I wired up those spare 2 wires to a power source and my world lit up (well the gauge did)
I could have wired it up like the manual suggests but wasn't bothered with the needle re-zeroing after turning the ignition off so saved a bit of hassle by joining them all to an single ignition power source.
Bit gutted that the orange back light didn't match the oem gauges in the Z so just keeping it red.
  • 2 months later...
Started to strip the car in prep.
IMG_20130112_144203_zpsaef0c222.jpgIMG_20130112_150814_zps942858eb.jpgIMG_20130112_154545_zps5d1a1ccd.jpg
Then unfortunately I check my inbox to which I have a worried Chris saying the parcel tracking doesn't look good as there has been no movement since wed night. :scare: Hopefully I will eventually receive my supercharger, just having problems with plonkers the other side of the pond. :dry:
Walbro 255 fuel pump install
pump carrier out
Uncliped all the electrical connectors so two halfs can come apart
Filter was a little dirty, uncliped the plastic bracket that secures the old pump in place
pushed down on the electrical connector on top of the old pump to slide it out,took a bit of force.
swap over the rubber seal at the top
Remove the locking spring washer that keeps the filter on the pump
sawed off the 3 tabs at the bottom of the pump
Then you can fit the cap back on (see picture to see which 3 tabs to saw off, you will maybe want to test fit before you attach the filter to the new pump)
Then swapped over the plastic and rubber o-rings from the old pressure regulator
Drilled a hole using a 10mm drill(had to also file it larger as I didnt have any larger drill bits :dry: not much filing tho)
so I could fit the 90* AAM fuel return pipe that will eventually connect to the return line. (instructions were not great to find which way the plastic washer and rubber o-ring went, may have got this wrong but it seems a tight enough seal.)
Connected the top 90* pipe down to the replaced pressure reg which has a fitting on it
This was a nightmare to get off :rant: used a 1.8mm drill bit to increase the swirl jet size
All back together, but had to problem solve, the two units would not compress. Noticed that one of the tabs on the pressure regulator cap was fouling against the swirl jet housing, just needed to pull the housing to the side to allow the units to compress properly.
Back in the tank
Before I start, wanted to say thanks to Keyser for the heads up on how much of a pain in the butt :rant: this job was.
Had a go at feeding the new fuel return line up from under the car beside the old fuel lines and to the new fitting on the walbro (fuel pump housing)
Spent 30mins looking at a 90* plastic cover that protects the fuel lines and carriers before it goes up past the fuel tank.
Couldnt find any pictures or info on the lines/clips etc in the manual and the cover had some rusted plates with square plastic blocks poking through.
Finally realised that under all the rust were some tabs to push in to remove the cover however one was so far up and out of reach it caused some frustration :lol:
Used a cable tie to feed some string down the uber tight path beside the other fuel lines then attached this to the end of the new hose fitting and with my dad in the car pulling the string and me pushing the hose we managed to get the hose up and over the tank, not a fun job when you barely have enough room to turn your head under the car(own fault should have used taller axle stands).
Managed to do all the hard work but have been stumped by the fuel line carrier/clamps, the three at the fuel tank were slightly loose and easily managed to pop off one of the oem lines so I could fit the new line in the carrier but the rest of the clamps are solid against the car and not quite sure the correct technique to get them off without breaking them????
