Help!
ric
Hi guys,
Hope all is well. This place looks very different!!
I had my MOT done a few weeks ago, and on it they noted:
Rear Tie bar/rod slightly distorted
Rear Tie bar/rod corroded but seriously weakened
The garage that I use have mentioned this to me previously, and said I'd pop in so they could point out to me exactly which piece needs attention/replacing but I've just not got around to it.
I've just had my car serviced by Nissan today, and they noted:
rear body anti-twist bar bardly corroded and pushed towards fuel tank
So obviously I want to get this seen to. Nissan have quoted me quite a lot to fix, but I wanted to get a feel for:
- Exactly what this part is
- what sort of prices I should be paying
- If I can get any aftermarket upgraded parts instead
I have google'd this afternoon and can't really find anything which is described as the above that pin points exactly what this item is, does anyone know?
I believe the part number is 74870CD2000 but I have no way of searching or referencing this unfortunately.
Any help much appreciated!
Cheers,
Edited by ric
Well, a quick look at a Whiteline Adjustable Rear Anti-Roll Bar is around £170.
So that is the cost of parts I am assuming...
I am assuming that is the part... can't think of any other Anti-Twist / Tie-Rod Bar.
Yeah, I asked if it was the anti-roll bar, but he said not.
After google'ing all night, I think i've found it:
http://www.conceptzperformance.com/cart/description.php?II=6623&Car_Type=NIS350&UID=2012070900564066.249.73.1
Having said that though, I can't really seem to find anything UK based for this part. Does anyone know if the above part is what I talked about in the above?
Thanks in advance
Is it just an reinforcement bar?
Is it part of the subframe?
Is it even needed there?
Not something I come across personally.
Good luck, and let us know how you get on.
To be honest, I guess they are the questions I'm asking, I have no idea lol!
Hopefully someone will......
Yes
No But indirectly bolts to it.
Yes (Well Nissan seem to think so ;) )
The "W" bar goes across the rear just in front of the wheels and strengthens the chassis, thread a while ago where someone cut a bit out to fit a Zorst :scare:
They do rust badly and if that's the part you need :pmzmanalex:
I wondered if they meant the drop links? Best double check
