Zugara Posted October 10, 2012 Share Posted October 10, 2012 Noticed that the "key" icon is illuminated in my car now, car runs fine, changed fobs and battery's in them with no difference, goes out if I restart the engine though..... Suggestions Quote Link to comment Share on other sites More sharing options...
Jay Posted October 10, 2012 Share Posted October 10, 2012 Noticed that the "key" icon is illuminated in my car now, car runs fine, changed fobs and battery's in them with no difference, goes out if I restart the engine though..... Suggestions Burn it Quote Link to comment Share on other sites More sharing options...
glrnet Posted October 10, 2012 Share Posted October 10, 2012 Do more miles Quote Link to comment Share on other sites More sharing options...
ioneabee Posted October 10, 2012 Share Posted October 10, 2012 Try sticking the fob manually into the receiver Quote Link to comment Share on other sites More sharing options...
R35LEE Posted October 10, 2012 Share Posted October 10, 2012 My car did this last week. battery changed at issue went away. I would plug into to diagnostic to see if anything is stored Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 10, 2012 Author Share Posted October 10, 2012 Noticed that the "key" icon is illuminated in my car now, car runs fine, changed fobs and battery's in them with no difference, goes out if I restart the engine though..... Suggestions Burn it Ta Quote Link to comment Share on other sites More sharing options...
doctor austin Posted October 10, 2012 Share Posted October 10, 2012 wont be battery as the way it works is the fob is waiting for a signal from the transmitter in the car when this happens it turns the signal into power to run a circuit in the fob to give a handshake...The fob can have problems if its near a mobile phone or some stray signal. The battery in the fob only works if you have to use the buttons on the fob......Well thats the way it works...!! Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 10, 2012 Author Share Posted October 10, 2012 Strange think is it only does it in the evening, not ever in the mornings, thought it could be cos I had the key in my jacket but nagh....... Quote Link to comment Share on other sites More sharing options...
Jay Posted October 10, 2012 Share Posted October 10, 2012 Noticed that the "key" icon is illuminated in my car now, car runs fine, changed fobs and battery's in them with no difference, goes out if I restart the engine though..... Suggestions Burn it Ta Hey you didnt ask for useful suggestions Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 10, 2012 Author Share Posted October 10, 2012 Noticed that the "key" icon is illuminated in my car now, car runs fine, changed fobs and battery's in them with no difference, goes out if I restart the engine though..... Suggestions Burn it Ta Hey you didnt ask for useful suggestions True........ Quote Link to comment Share on other sites More sharing options...
Will370z Posted October 10, 2012 Share Posted October 10, 2012 Not using the juke key by mistake are you Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 10, 2012 Author Share Posted October 10, 2012 Not using the juke key by mistake are you No........ Quote Link to comment Share on other sites More sharing options...
AFTERSHOX Posted October 10, 2012 Share Posted October 10, 2012 wont be battery as the way it works is the fob is waiting for a signal from the transmitter in the car when this happens it turns the signal into power to run a circuit in the fob to give a handshake...The fob can have problems if its near a mobile phone or some stray signal. The battery in the fob only works if you have to use the buttons on the fob......Well thats the way it works...!! I've seen the interference problem a few times with other cars; the most common culprit was wireless doorbell systems !!! Bit odd how it's only evenings though? *scratches head* Hope you find out what's causing it.... Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 10, 2012 Author Share Posted October 10, 2012 Just found this.... viewtopic.php?f=102&t=65216 Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted October 10, 2012 Share Posted October 10, 2012 Perhaps your neighbours are jamming the signal Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted October 11, 2012 Share Posted October 11, 2012 It probably just wants to be driven Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 11, 2012 Author Share Posted October 11, 2012 It probably just wants to be driven It gets driven....... Quote Link to comment Share on other sites More sharing options...
Sly@Kaizer Motor Posted October 11, 2012 Share Posted October 11, 2012 You need to check for fault codes in Intelligent Key System if no code, than need a to do a function check. (As far as I know it is only possible with Consult 3). This fault usually caused by faulty key or antenna (rarely receiver ECU or interference with other radio signals (try to get a same fault at different place to rule out interference)). Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 11, 2012 Author Share Posted October 11, 2012 You need to check for fault codes in Intelligent Key System if no code, than need a to do a function check. (As far as I know it is only possible with Consult 3). This fault usually caused by faulty key or antenna (rarely receiver ECU or interference with other radio signals (try to get a same fault at different place to rule out interference)). Done different locations, different fobs no difference. Quote Link to comment Share on other sites More sharing options...
Sly@Kaizer Motor Posted October 11, 2012 Share Posted October 11, 2012 You need to check for fault codes in Intelligent Key System if no code, than need a to do a function check. (As far as I know it is only possible with Consult 3). This fault usually caused by faulty key or antenna (rarely receiver ECU or interference with other radio signals (try to get a same fault at different place to rule out interference)). Done different locations, different fobs no difference. Than it's possible you have an internal fault of the I-Key ECU have it checked by a specialist or Nissan Dealer if you are brave enough Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 11, 2012 Author Share Posted October 11, 2012 You need to check for fault codes in Intelligent Key System if no code, than need a to do a function check. (As far as I know it is only possible with Consult 3). This fault usually caused by faulty key or antenna (rarely receiver ECU or interference with other radio signals (try to get a same fault at different place to rule out interference)). Done different locations, different fobs no difference. Than it's possible you have an internal fault of the I-Key ECU have it checked by a specialist or Nissan Dealer if you are brave enough Should come under Nissan Warranty I guess it's only a 10 plate with 7 k on the clock. Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 11, 2012 Author Share Posted October 11, 2012 Ok.... Been doing some Internet searching from across the pond, this problem seems mainly to affect 2009/2010 370z. Loads of issues in USA. There was mentions of hearing the wheel lock whir in and out when the cars ignition is turned off/ on, but when switched off it won't fire until the door is opened. Anyway, I never got the whirring noise, so it must have been jammed in the unlock position fortunately. I turned the wheel with the ignition off and door closed to its full turning circle both ways, in one direction I heard a positive clunk and the wheel was locked, pressed the start button and heard the whir of the locking pin being pulled out, wheel now free to turn, so I am hoping that was the issue.......... Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 16, 2012 Author Share Posted October 16, 2012 Update..... New lock being fitted under nissan warranty.....phew.....unit cost is £1200! Dodged a bullet there.... Quote Link to comment Share on other sites More sharing options...
Will370z Posted October 16, 2012 Share Posted October 16, 2012 good to hear you got it sorted Quote Link to comment Share on other sites More sharing options...
Jay Posted October 16, 2012 Share Posted October 16, 2012 Update..... New lock being fitted under nissan warranty.....phew.....unit cost is £1200! Dodged a bullet there.... Ouch Good result tho Quote Link to comment Share on other sites More sharing options...
