Rusty or what
4RE Leather
The story so far.
Today I made some alterations to the stock so it could take an uprated trigger guard.
The one on the rifle was a nasty plastic thing.
The replacement a black one of Alloy construction.
2 min job with the dremel and some woodstain and job done:)
Pre stain
The next job was the barrel blueing.
For this I used a Jell from makers Bisley
A highly toxic dangerous product that um well a kid can get hold of it over the counter or online!!!
1st wipe down the metal with sovent or white spirit.
Then I used a soft brush and you just dip it in the pot (Gloves are a must) and dab it on.
let it dry for approx 30-40 secs then wash off with cold water.
I use a cotton wool ball and let the cold tap run over the item.
Repeat the above 3-4 times until your sure that the area is fully treated and will not take any more blueing.
After the treatment wipe dry and apply 3-1 or Gun oil to the whole area and buff up to a shine.
You will have to repeat the oiling several times especially after the build until a deep luster is achieved:)
I am now repeating the process on all the externals like barrel and sping housing/ lever and sights.
This is the barrel after the 1st coat of oil.
Certainly different from the rusty one of 2 weeks ago!!
Edited by 4RE Leather
To give those who dont know an insight intoAir Rifle mainsprings and there power, here are a few I have obtained;
The max legal limit in UK is 12 ft lbs or 12 foot pounds of kinetic energy.
Top one is the original i took out of the Diana G80 restore project and is approx 9ft lbs
2nd is a 12 ft lbs legal limit for none FAC or Fire Arms certificate Holder
This is the original factory from my HW97 in picture in thread.
3rd one is a OX spring accelerator and is approx 17-20 ft lbs and is the one I hope to use
as it is smaller diameter and a direct replacement for the G80.
Notice the spring has square coils not round! This makes for a much stronger compression
and is up to 40% stronger than a factory fitted round one!
4th was the one I wanted to use but would not fit as to fat. Again 17-20 ft lbs
5th Is for a Webley Patriot and my 1st FAC rifle. Approx 32 ft lbs of energy.
I believe the rating for this is comparable to a small car if not more but I will out of interest get the figures.
I might see if I can get this in the HW97 without having to take a couple of coils out.
Incidently they make a power spacer in all sizes as well.
These are like a fat washer the width of 1 coil.
They are inserted 1st into the piston chamber prior to the spring and eash one can put up to 1-2 ft lbs increase.
You may wonder how I intend to compress the spring to get it in the chamber.
Well a shop bought compressor can cost upwards of £150-£200 and i am not paying that!
so I intend to make one using a G clamp or a Sash clamp over the weekend for about £50.
Things have ground to a halt at the moment as I need to get this leather piston seal washer sorted out.
I have found a shop that sells everything I need down in Bognor.
I went to get in the car this morning to go down there and as soon as I sat in the seat the Sciatica said to me.
You aint going no where!!
So back to bed Arrrrhhh
The shop cant send it to me as I need to take the piston down to get it matched up.
Aparently there were several diferent ones.
If I dont get it right 1st time I will have to dismantle it and damage the piston guide and backing plate that also need to be replaced.
I can actually buy a 2nd hand rifle for half of what this is costing to do up, but where is the fun in that!
And as soon as this is done I will do another one.
I am already looking at a turn of the century BSA and a 60 year old pistol.#
I wont use wood stain and varnish on the next one but go down the more traditional route of using a red stain that comes from a plant root,
Before the stain you use a grain filler and sealer. Then its polished over a week with a special oil.
I did the Lee Enfield in it and it looks awsome.
