GIXXERUK Posted September 12, 2014 Share Posted September 12, 2014 On 12/09/2014 at 21:34, Watshot said: It's because, as Jetset has already pointed out in post 19, the rollers are run one side at a time before being run simultaneously. This can potentially damage a LSD (and any 4wd set up). And don't rely on the computer flagging up your lsd to the tester. This info was in the 1st post: "You also asked whether the fact that the vehicle has a limited slip differential fitted it would be flagged up to the tester. This fact would not be drawn to the tester s attention by the system as this information is not recorded on our database" It was flagged when I had an mot but I've always told them anyway, with both the 350 and 370 ( most don't know ) It has only flagged once in prob 5 mot's Quote Link to comment Share on other sites More sharing options...
Omegamanuk Posted December 5, 2015 Share Posted December 5, 2015 What would be the signs of the lsd having been damaged Quote Link to comment Share on other sites More sharing options...
