gort Posted October 5, 2012 Share Posted October 5, 2012 Hi Guys. The windscreen washer motor is working, but there's no water coming out of the jets, the rear washer and the headlight washers work OK. I've had the car in the bodyshop for a front bumper re-spray, maybe they've dislodged the washer tube in some way?,( I can't think of anything else it could be) is it easy to get to the area where the motor is located. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
marzman Posted October 5, 2012 Share Posted October 5, 2012 Take off the brake fluid cover and reach under the windscreen cowling. Unhook the pipes from under there and disconnect at either the Y-join or the non return valve and try running the washers. If water comes through, its narrowed down your problem. Expect it's likely the non return valve which needs replacing. Quote Link to comment Share on other sites More sharing options...
gort Posted October 5, 2012 Author Share Posted October 5, 2012 thanks for the reply, the car's booked in for a MOT on Monday, would that be a fail? Quote Link to comment Share on other sites More sharing options...
Watshot Posted October 5, 2012 Share Posted October 5, 2012 Yes it would. You need front screen washers to work effectively for an mot pass. Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 5, 2012 Share Posted October 5, 2012 Oh.........maybe they are blocked Quote Link to comment Share on other sites More sharing options...
gort Posted October 6, 2012 Author Share Posted October 6, 2012 Expect it's likely the non return valve which needs replacing. That's exactly what it was, replaced it with a straight though connector thanks a lot, people. Quote Link to comment Share on other sites More sharing options...
marzman Posted October 6, 2012 Share Posted October 6, 2012 Expect it's likely the non return valve which needs replacing. That's exactly what it was, replaced it with a straight though connector thanks a lot, people. The same non return valve is about £2 in Halfords if you want to replace it. Quote Link to comment Share on other sites More sharing options...
gort Posted October 6, 2012 Author Share Posted October 6, 2012 thanks I'll get one. will it do any damage in the meantime? Quote Link to comment Share on other sites More sharing options...
jollyranchers Posted October 6, 2012 Share Posted October 6, 2012 My problem is when I pull the lever for the washers the wipers start moving across a dry windscreen for a couple of wipes before the spray comes through. The actual spray coming through isnt that high pressure , it's always been like this since I have had it , either I have a problem or all z cars are like this? Anyone else have this problem , wipers start wiping without spray ? Quote Link to comment Share on other sites More sharing options...
gort Posted October 6, 2012 Author Share Posted October 6, 2012 I noticed when I replaced the valve with a in line connector, the pressure was very fast, maybe yours is partially blocked? Quote Link to comment Share on other sites More sharing options...
marzman Posted October 6, 2012 Share Posted October 6, 2012 Exactly that, swap the valve and they will work much better. Gort, no harm in leaving it open, however i think under spirited driving, in theory your washer fluid could come through your wipers despite you not pressing the button for it. Quote Link to comment Share on other sites More sharing options...
14N Posted October 9, 2012 Share Posted October 9, 2012 I very recently had the same symptoms and issue viewtopic.php?f=9&t=66317. A new valve sorted it Quote Link to comment Share on other sites More sharing options...
JetSet Posted October 9, 2012 Share Posted October 9, 2012 My problem is when I pull the lever for the washers the wipers start moving across a dry windscreen for a couple of wipes before the spray comes through. The actual spray coming through isnt that high pressure , it's always been like this since I have had it , either I have a problem or all z cars are like this? Anyone else have this problem , wipers start wiping without spray ? No, mines fine, plenty of pressure. Pete Quote Link to comment Share on other sites More sharing options...
