Gerry67 Posted October 4, 2012 Share Posted October 4, 2012 Hiya all I have a slight problem. I have a 2005 zed which when is out of gear and the clutch depressed it is making a strange noise. As soon as I press the clutch in, it gets away. Any suggestions? Gerry Quote Link to comment Share on other sites More sharing options...
Husky Posted October 4, 2012 Share Posted October 4, 2012 Most likely your clutch release bearing that's causing the noise. sounds a bit like a distant cement mixer Quote Link to comment Share on other sites More sharing options...
marzman Posted October 4, 2012 Share Posted October 4, 2012 Have you had the flywheel changed? If you have a lightweight fly, it grumbles a bit when the clutch is out, but when pressed in it goes away. Perfectly normal. Quote Link to comment Share on other sites More sharing options...
Gerry67 Posted October 4, 2012 Author Share Posted October 4, 2012 Not sure about fly wheel. Only got the car a couple of months ago. Yeah, bit like a cement mixer Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted October 5, 2012 Share Posted October 5, 2012 Have you had the flywheel changed? If you have a lightweight fly, it grumbles a bit when the clutch is out, but when pressed in it goes away. Perfectly normal. Same here Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted October 5, 2012 Share Posted October 5, 2012 Snap. Quote Link to comment Share on other sites More sharing options...
Wasso Posted October 5, 2012 Share Posted October 5, 2012 The trait of a Zed. Quote Link to comment Share on other sites More sharing options...
Neilp Posted October 5, 2012 Share Posted October 5, 2012 Is search still not working? Quote Link to comment Share on other sites More sharing options...
glrnet Posted October 5, 2012 Share Posted October 5, 2012 Is search still not working? No mate, but use google with 350z-uk.com and the topic in the search and it should find it Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted October 5, 2012 Share Posted October 5, 2012 Id see if you can listen to another zed and see if its the same. I think they all do this to some degree. My HR with only 22k on the clock was making a noise which sounded very much like a release bearing also. Its apparently normal, and didnt cause me any problems over the next 20k i did in the car before selling it. Quote Link to comment Share on other sites More sharing options...
