skylineg14 Posted October 4, 2012 Share Posted October 4, 2012 having checked all plugs under seats ,reset system light still flashing any one more things to try ? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 4, 2012 Share Posted October 4, 2012 You could have a broken wire in the loom in the back of the seat. I had this issue. Fixed simply with a bit of soldering once I found where the break was. Thankfully the seat covers have a zip at the back for access Quote Link to comment Share on other sites More sharing options...
skylineg14 Posted October 6, 2012 Author Share Posted October 6, 2012 removed seats this morning small plug goes straight to seatbelt switch large plug has 4 wire 1 earth 2 +12v for power seats 3 switched 12v seat bottom heat pad 4 switched 12v seat back heat pad cant find anything to do with air bag light any ideas Quote Link to comment Share on other sites More sharing options...
dErZ Posted October 6, 2012 Share Posted October 6, 2012 What error code are you getting? Quote Link to comment Share on other sites More sharing options...
skylineg14 Posted October 6, 2012 Author Share Posted October 6, 2012 after trying reset light goes out for 2 seconds comes on solid for2 seconds goes out for 2 seconds then flashes again Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 7, 2012 Share Posted October 7, 2012 Check the loom in the seat as per my previous post Quote Link to comment Share on other sites More sharing options...
leonk Posted October 7, 2012 Share Posted October 7, 2012 +1 Had this problem on a BMW ended up going to a garage to get them to plug a diagnostic tester in. It actually pinpoints it to which sensor is activating the light. Turned out to be passenger seat wire / sensor. £30 for diagnostic and soldered the wire myself. At least if you have exhausted everything else you could try this. NB you need a proper airbag diagnostic device rather than the hand held OBD reader. Quote Link to comment Share on other sites More sharing options...
