Paul K Posted August 10, 2016 Share Posted August 10, 2016 Finally fitted the new wheel nuts that I bought at Japfest!!! Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
kayjay0_7 Posted August 12, 2016 Share Posted August 12, 2016 A quick and cheap modification Got these caps to fit over the strut tops , they fit perfectly 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted August 12, 2016 Share Posted August 12, 2016 ^^ Great idea kayjay. Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 12, 2016 Share Posted August 12, 2016 Neat thanx for sharing Quote Link to comment Share on other sites More sharing options...
sasha@lazytrips Posted August 12, 2016 Share Posted August 12, 2016 New exhaust New wheels New suspension Full wheel alignment Fuel tank senders sorted New cameras hardwired in front and back Tracker wired in New undertray Rear wheelarches rolled Full bodywork rework New lower frame New struts New mats Aircon redone Full P3 service Rear wiper motor replaced ... I iz sorted Quote Link to comment Share on other sites More sharing options...
Dicaprio Posted August 12, 2016 Share Posted August 12, 2016 On 12/08/2016 at 22:35, sasha said: New exhaust New wheels New suspension Full wheel alignment Fuel tank senders sorted New cameras hardwired in front and back Tracker wired in New undertray Rear wheelarches rolled Full bodywork rework New lower frame New struts New mats Aircon redone Full P3 service Rear wiper motor replaced ... I iz sorted How did you sort out tye fuel tank sender? Quote Link to comment Share on other sites More sharing options...
sasha@lazytrips Posted August 12, 2016 Share Posted August 12, 2016 On 12/08/2016 at 23:22, Dicaprio said: On 12/08/2016 at 22:35, sasha said: New exhaust New wheels New suspension Full wheel alignment Fuel tank senders sorted New cameras hardwired in front and back Tracker wired in New undertray Rear wheelarches rolled Full bodywork rework New lower frame New struts New mats Aircon redone Full P3 service Rear wiper motor replaced ... I iz sorted How did you sort out tye fuel tank sender? There's a guide on here. Have to open up both senders from inside the cabin and clean the metal strips. 1 Quote Link to comment Share on other sites More sharing options...
Bob94 Posted August 17, 2016 Share Posted August 17, 2016 (edited) Not a mod a such but finally got a flip key....and it all works now. Wasn't too bad swapping internals over but a bit chewy getting the buttons to line up and get them to feel how I wanted. Sent from my iPhone using Tapatalk Edited August 17, 2016 by Bob94 1 Quote Link to comment Share on other sites More sharing options...
Erni902 Posted August 18, 2016 Share Posted August 18, 2016 (edited) On 17/08/2016 at 07:40, Bob94 said: Not a mod a such but finally got a flip key....and it all works now. Wasn't too bad swapping internals over but a bit chewy getting the buttons to line up and get them to feel how I wanted. Sent from my iPhone using Tapatalk This is a 'mod' that I get round to doing on all my cars. Where did you source the fob from and what was the cost? Edited August 18, 2016 by Erni902 Quote Link to comment Share on other sites More sharing options...
Erni902 Posted August 18, 2016 Share Posted August 18, 2016 (edited) After I got rid of the 2x 10" subs that were taking up all my boot space it was time to remove the twin amps that 'weren't hooked up' from when I bought the car. There was some wiring hanging around in the boot so removed it all from the two amps yesterday and removed the amps from the car. Leaving the wiring for today. Upon heading to the post office earlier it became apparent that the amps had infact been connected to the speakers and the headunit as I now no longer had any sound. Oh well, cue Nismo FM I got back and after work set upon sorting the audio out. As it happens the headunit that had been installed had bypassed the factory system hence the previous owner decided to hook up aftermarket kit. After a little play I managed to re-install 1 of the amps (2 is overkill at my age) and wired it all up to the factory Bose Sub. Fairly simple job as all the wiring had been done for me I just had to re-route some of it and modify the tray in the passenger cubby hole as this is where I have installed the amp. I noticed that originally some of the speakers were not working and the sound was very very low and the sub was obviously not hooked up. This was due to the wires not being stripped enough so when they were connected to the amp the clamp was on the insulation and not the wire itself. Sorted that all out and run a new cable from the stock Sub to the Alpine amp and now it is all back in and working. Sound is now fantastic without being over the top. Didnt get any pics as it was dark by the time I tidied everything up and got her finished off. Will grab some tomorrow in the light. Just managed to get a pic on the daylight of where I have located the amp and fixed her down: I just need to buy a stock Bose sub cover that I can then place on instead of the cubby door to ensure enough airflow gets to the amp and she doesnt get too hot. For now though I will just prop the cubby door open when driving. Next job is to get a thin piece of wood and some black carpet and create a screen/divider of some kind that covers the boot at an angle so nobody can see what I have inside. Edited August 19, 2016 by Erni902 Quote Link to comment Share on other sites More sharing options...
350jimbobz Posted August 18, 2016 Share Posted August 18, 2016 Someone was selling a factory tailgate divider on here mate Quote Link to comment Share on other sites More sharing options...
Erni902 Posted August 18, 2016 Share Posted August 18, 2016 On 18/08/2016 at 21:43, 350jimbobz said: Someone was selling a factory tailgate divider on here mate What I am after mate is something to cover the boot area from the front. So if people look through the windscreen or side windows they cant see through into the boot. Something that covers the area similar to the pic below: Going to make something up that covers from the top of the part where the rear speakers are and goes up at an angle to the top of the strut bar. Quote Link to comment Share on other sites More sharing options...
Ollydykins Posted August 19, 2016 Share Posted August 19, 2016 On 05/05/2016 at 19:49, Andy_Muxlow said: I have just started as only owned mine for a couple of weeks but I have changed my interior lights to led and my number plate lights also to led. Sent from my iPhone using Tapatalk Are these an eBay find ? Thanks, Olly Quote Link to comment Share on other sites More sharing options...
Bob94 Posted August 19, 2016 Share Posted August 19, 2016 On 18/08/2016 at 20:56, Erni902 said: On 17/08/2016 at 07:40, Bob94 said: Not a mod a such but finally got a flip key....and it all works now. Wasn't too bad swapping internals over but a bit chewy getting the buttons to line up and get them to feel how I wanted. Sent from my iPhone using Tapatalk This is a 'mod' that I get round to doing on all my cars. Where did you source the fob from and what was the cost? Got it off eBay wasn't very expensive at all then cost my £9 to get the blade cut. Sellers name is written across the picture Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
modo Posted August 19, 2016 Share Posted August 19, 2016 Good idea Sent from my HTC One M9 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Andy_Muxlow Posted August 19, 2016 Share Posted August 19, 2016 On 19/08/2016 at 03:56, Ollydykins said: On 05/05/2016 at 19:49, Andy_Muxlow said: I have just started as only owned mine for a couple of weeks but I have changed my interior lights to led and my number plate lights also to led. Sent from my iPhone using Tapatalk Are these an eBay find ? Thanks, Olly Hi Olly, Yes I got them off eBay buddy they were about £3 I think. Sent from my iPhone using hammer and chisel! Quote Link to comment Share on other sites More sharing options...
Ollydykins Posted August 19, 2016 Share Posted August 19, 2016 On 19/08/2016 at 14:44, Andy_Muxlow said: On 19/08/2016 at 03:56, Ollydykins said: On 05/05/2016 at 19:49, Andy_Muxlow said: I have just started as only owned mine for a couple of weeks but I have changed my interior lights to led and my number plate lights also to led. Sent from my iPhone using Tapatalk Are these an eBay find ? Thanks, Olly Hi Olly, Yes I got them off eBay buddy they were about £3 I think. Sent from my iPhone using hammer and chisel! Don't suppose you've got a seller/link? 1 Quote Link to comment Share on other sites More sharing options...
Erni902 Posted August 19, 2016 Share Posted August 19, 2016 (edited) On 19/08/2016 at 17:14, Ollydykins said: Don't suppose you've got a seller/link? Couldnt find a set of the lights on ebay so just bought individual ones from different sellers. I also replaced the lights above the vanity mirrors on the sun visors. Links below: Main interior lights. Qty Supplied = 2 Qty Needed = 2: http://www.ebay.co.uk/itm/162067658940?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Boot Light. Qty Supplied = 2. Qty Needed = 1: http://www.ebay.co.uk/itm/201485932808?_trksid=p2060353.m2749.l2649&var=500665217763&ssPageName=STRK%3AMEBIDX%3AIT Sun Visor Vanity Light. Qty Supplied = 2. Qty Needed = 2: http://www.ebay.co.uk/itm/151582305469?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT I didnt replace the number plate lights as they were already bright white so havent got a link. Hope this helps mate, I didnt do much searching I just ordered the 1st ones I saw by a UK seller. There are probably cheaper ones out there but cant really grumble at these prices anyway and I have a spare bulb aswell. I will say the boot one isnt a perfect fit and could do with narrowing the connectors it plugs into as it seems a little loose but it has stayed where it is so far. Edited August 19, 2016 by Erni902 1 Quote Link to comment Share on other sites More sharing options...
Erni902 Posted August 19, 2016 Share Posted August 19, 2016 On 19/08/2016 at 07:19, Bob94 said: Got it off eBay wasn't very expensive at all then cost my £9 to get the blade cut. Sellers name is written across the picture Sent from my iPhone using Tapatalk Cheers mate thats fantastic. I always just use the original key as I have a dremel so can make it fit into the flip case 1 Quote Link to comment Share on other sites More sharing options...
MikeyM Posted August 21, 2016 Share Posted August 21, 2016 Got lights back together at last.... Couple of disappointments..DRL'S are not bright enough sadly.. and custom lighting have not managed to give me sequential Leds without a break in them for the 2nd time ! Quote Link to comment Share on other sites More sharing options...
Andy_Muxlow Posted August 21, 2016 Share Posted August 21, 2016 On 19/08/2016 at 07:19, Bob94 said: On 18/08/2016 at 20:56, Erni902 said: On 17/08/2016 at 07:40, Bob94 said: Not a mod a such but finally got a flip key....and it all works now. Wasn't too bad swapping internals over but a bit chewy getting the buttons to line up and get them to feel how I wanted. Sent from my iPhone using Tapatalk This is a 'mod' that I get round to doing on all my cars. Where did you source the fob from and what was the cost? Got it off eBay wasn't very expensive at all then cost my £9 to get the blade cut. Sellers name is written across the picture Sent from my iPhone using Tapatalk Hi Bob, How easy was this to complete please? As just bought the stuff of eBay gum... Sent from my iPad using a hammer and chisel... Quote Link to comment Share on other sites More sharing options...
Bob94 Posted August 21, 2016 Share Posted August 21, 2016 It was easy enough just have to swap the circuit board over minus the jelly rubber that's inside the original key cause it doesn't all fit inside new fob. Don't forget the tiny bit of metal that is with the battery on the side of the original key (like I did and wonder why it didn't work at first 🙈😉). I used a bit of tissue to keep the circuit board in place while joining the two halves of the new key and to give the buttons the feel I wanted. Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted August 21, 2016 Share Posted August 21, 2016 Blu tac is useful for holding stuff together and giving it some heft. Quote Link to comment Share on other sites More sharing options...
Gus-350z Posted August 25, 2016 Share Posted August 25, 2016 Not exactly today-but over the last couple of days: completely overhauled the audio system. Stripped the lot out and then fitted: focal components upfront with passive crossovers, powered by an alpine 300W amp. Then some alpine coaxials in the rear and a pioneer sph da 120 HU. Also sorted some sound deadening and insulation etc and all new wiring. Sounds absolutely incredible! And love the HU, would definitely recommend it. Then whilst I was at it, also replaced boot, number plate and interior bulbs with leds which really look great and very classy IMO. Also removed the boot weight so it actually pops up now! And painted and fitted some custom Zed centre caps to go with the black wheels Don't worry, pics to follow when I'm back on my laptop! 3 Quote Link to comment Share on other sites More sharing options...
Erni902 Posted August 26, 2016 Share Posted August 26, 2016 (edited) Ok so I like to carry a toolbox around with me wherever I go. Nothing special just a set that has anything you would need at the side of the road. I have owned modified cars before and know that anything can happen. There is nothing worse than calling the AA because of a simple fix such as a turbo hose clamp needs tightening as the garage that youve just picked it up from didnt tighten it enough and it popped off on the dual carriageway when you floored it (Yes that has happened and it was damn scary especially when the engine died (after a big bang) as I was coming off the slip road meaning no power steering and no ABS!!) Anyway I digress, the only issue with the Zed is that my tool box and anything else I have in the boot is visible from the outside of the car through the front and side windows. To combat this I have made up a type of parcel shelf that sits behind the rear speakers and heads back to meet the strut bar. I then covered it in back felt so it now blends in and from a distance looks rather factory. Could do with an orange 'Z' logo in the centre of it though: Edited August 26, 2016 by Erni902 1 Quote Link to comment Share on other sites More sharing options...
