Ceejay29 Posted April 15, 2014 Share Posted April 15, 2014 Had my ARK lowering springs & eibach spacers fitted at CS And also had my rear windows tinted Phwooarr! She's a beauty!! 1 Quote Link to comment Share on other sites More sharing options...
Rocky4510 Posted April 15, 2014 Share Posted April 15, 2014 Again nothing new or exciting to most of you but finally got round to spraying my front bumper Sent from my HTC One X using Tapatalk Hi Lyndzzz, do you know the measurement of your number plate? I'm after one the same size Quote Link to comment Share on other sites More sharing options...
HoundDog Posted April 15, 2014 Share Posted April 15, 2014 Again nothing new or exciting to most of you but finally got round to spraying my front bumper Sent from my HTC One X using Tapatalk Hi Lyndzzz, do you know the measurement of your number plate? I'm after one the same size Again nothing new or exciting to most of you but finally got round to spraying my front bumper Sent from my HTC One X using Tapatalk Hi Lyndzzz, do you know the measurement of your number plate? I'm after one the same size Just what I'm after as well looking good. Where did you order from please and as Rocky said what size is it please. Thanks Quote Link to comment Share on other sites More sharing options...
HoundDog Posted April 15, 2014 Share Posted April 15, 2014 Had my ARK lowering springs & eibach spacers fitted at CS And also had my rear windows tinted Very nice 1 Quote Link to comment Share on other sites More sharing options...
Lyndzzz Posted April 15, 2014 Share Posted April 15, 2014 It's a 3/4 size plate from fancy plates, not exactly legal though Sent from my HTC One X using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 15, 2014 Share Posted April 15, 2014 Loving the 370 tatooandy67. Very nice stance. 1 Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted April 15, 2014 Share Posted April 15, 2014 All looking good Quote Link to comment Share on other sites More sharing options...
tatooandy67 Posted April 16, 2014 Share Posted April 16, 2014 Loving the 370 tatooandy67. Very nice stance. Thank you I'm very pleased with the results Mitz & his team did a great job Quote Link to comment Share on other sites More sharing options...
ECG1000 Posted April 16, 2014 Share Posted April 16, 2014 (edited) Well, I was supposed to be fitting my Buddy Club Type A gear knob. Had a struggle getting the OEM knob off and ended up mangling it! The Buddy Club knob was 12x1.25 instead of 10x1.25....! I was knob-less.... Had to get the old lathe into life and turn down some ratty wooden pole: Could do with some varnish but I actually quite like the feel of it. Got some good leverage, making changes a little easier... Correct size Buddy Club should arrive tomorrow... Having trouble finding the correct threaded Buddy Club knob so I decided to make a slightly more permanent knob out of nylon. Made it bigger than the wooden one and a bit shorter. Really like it actually. Got more weight to it and still gives good leverage....could be a keeper. Hard to see from the photo but there are 3 shallow grooves at the top and 2 larger ones at the bottom. Also dipped my fangs last night: Edited April 16, 2014 by ECG1000 2 Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 16, 2014 Share Posted April 16, 2014 Well, I was supposed to be fitting my Buddy Club Type A gear knob. Had a struggle getting the OEM knob off and ended up mangling it! The Buddy Club knob was 12x1.25 instead of 10x1.25....! I was knob-less.... Had to get the old lathe into life and turn down some ratty wooden pole: Could do with some varnish but I actually quite like the feel of it. Got some good leverage, making changes a little easier... Correct size Buddy Club should arrive tomorrow... Having trouble finding the correct threaded Buddy Club knob so I decided to make a slightly more permanent knob out of nylon. Made it bigger than the wooden one and a bit shorter. Really like it actually. Got more weight to it and still gives good leverage....could be a keeper. Hard to see from the photo but there are 3 shallow grooves at the top and 2 larger ones at the bottom. Also dipped my fangs last night: I dipped my fangs and rear valance, I found that the lower corners near the grill started to lift/bubble, so I tried again this time prepping it better but got the same result and had to remove it, let me know how it goes Quote Link to comment Share on other sites More sharing options...
Ceejay29 Posted April 16, 2014 Share Posted April 16, 2014 Fangs look great, much better! Quote Link to comment Share on other sites More sharing options...
ECG1000 Posted April 16, 2014 Share Posted April 16, 2014 I dipped my fangs and rear valance, I found that the lower corners near the grill started to lift/bubble, so I tried again this time prepping it better but got the same result and had to remove it, let me know how it goes Mine's a bit dodgy round the top part of the teeth where they go into a point. I ran a blade around the edges of the painted area as soon as I finished spraying, hoping that dip wouldn't lift when I pulled the masking tape off. Rear valance at the weekend and maybe badges... Quote Link to comment Share on other sites More sharing options...
ECG1000 Posted April 16, 2014 Share Posted April 16, 2014 Fangs look great, much better! Cheers dude Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 16, 2014 Share Posted April 16, 2014 (edited) I dipped my fangs and rear valance, I found that the lower corners near the grill started to lift/bubble, so I tried again this time prepping it better but got the same result and had to remove it, let me know how it goes I used a blade to score the dip, the rear is easier, I took the fog light out to do it I'm convinced it's the heat coming through the grill tthat softens the dip and makes it lift, both times it looked perfect for a couple of days Mine's a bit dodgy round the top part of the teeth where they go into a point. I ran a blade around the edges of the painted area as soon as I finished spraying, hoping that dip wouldn't lift when I pulled the masking tape off. Rear valance at the weekend and maybe badges... Quote within a quote .... iPhone ! Edited April 16, 2014 by GIXXERUK 1 Quote Link to comment Share on other sites More sharing options...
Darren350 Posted April 17, 2014 Share Posted April 17, 2014 I dipped my fangs and rear valance, I found that the lower corners near the grill started to lift/bubble, so I tried again this time prepping it better but got the same result and had to remove it, let me know how it goes I used a blade to score the dip, the rear is easier, I took the fog light out to do it I'm convinced it's the heat coming through the grill tthat softens the dip and makes it lift, both times it looked perfect for a couple of days Mine's a bit dodgy round the top part of the teeth where they go into a point. I ran a blade around the edges of the painted area as soon as I finished spraying, hoping that dip wouldn't lift when I pulled the masking tape off. Rear valance at the weekend and maybe badges... Quote within a quote .... iPhone ! Like Inception, but with quotes... Sent from my GT-I9300 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lyndzzz Posted April 21, 2014 Share Posted April 21, 2014 So the paint on my roof is in pretty bad shape with lots of scratches, blemishes and lacquer peeling. I decided wrapping it would be the way to go. Wrapped it yesterday after claying the roof to get it a smooth as possible but the paint/surface is in such poor shape the wrap looked $@?! showing all the imperfections, so off it came . I'll be taking her to my painter friend and getting it done properly!! In order to have something to show for this weekend I painted the plenum and finished off the engine bay tidy up 3 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 21, 2014 Share Posted April 21, 2014 ^^ Very nice Lyndzzz. What paint did you use on the plenum then in the end? Looks nice and glossy from where I'm sitting. Quote Link to comment Share on other sites More sharing options...
Lyndzzz Posted April 21, 2014 Share Posted April 21, 2014 (edited) Thank you I used a satin black rustoleum that I had lying about, not sure if it'll stand up to the heat yet, but I can always redo it if need be! Edited April 21, 2014 by Lyndzzz Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 21, 2014 Share Posted April 21, 2014 ^^ Fingers crossed it holds up as it looks great. 1 Quote Link to comment Share on other sites More sharing options...
Lyndzzz Posted April 21, 2014 Share Posted April 21, 2014 Me too, as I think it looks pretty good Quote Link to comment Share on other sites More sharing options...
tatooandy67 Posted April 21, 2014 Share Posted April 21, 2014 So the paint on my roof is in pretty bad shape with lots of scratches, blemishes and lacquer peeling. I decided wrapping it would be the way to go. Wrapped it yesterday after claying the roof to get it a smooth as possible but the paint/surface is in such poor shape the wrap looked $@?! showing all the imperfections, so off it came . I'll be taking her to my painter friend and getting it done properly!! In order to have something to show for this weekend I painted the plenum and finished off the engine bay tidy up Looks sweet, love the colour Quote Link to comment Share on other sites More sharing options...
Stu_2424 Posted April 21, 2014 Share Posted April 21, 2014 Fitted side steps from Tarmac Sent from my iPad using Tapatalk 4 Quote Link to comment Share on other sites More sharing options...
tatooandy67 Posted April 21, 2014 Share Posted April 21, 2014 (edited) Fitted side steps from Tarmac Sent from my iPad using Tapatalk Looks sweet, got a set of these on my to do list, are you leaving them black or painting them ? Nice looking zed btw 👠Edited April 21, 2014 by tatooandy67 Quote Link to comment Share on other sites More sharing options...
KyleR Posted April 21, 2014 Share Posted April 21, 2014 I washed the Zed Best mod ever!! Quote Link to comment Share on other sites More sharing options...
Stu_2424 Posted April 21, 2014 Share Posted April 21, 2014 Fitted side steps from Tarmac Sent from my iPad using Tapatalk Looks sweet, got a set of these on my to do list, are you leaving them black or painting them ? Nice looking zed btw 👠Leaving them black I like the gloss black against the Gunmetal Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
