Help needed please. Ball joints!
Dblock
Hi guys,
I've been wanting to do a suspension refresh on my car for a while now including bushes etc. Now I also want to change the ball joint hub, this one
I'm sure this is the lower control arm. The one that has the shock bolted to it.
with this part Zman. Is that right? That is the right ball joint for the arm isnt it?
Now the compression arm which looks like
Has a ball joint on it. Can this ball joint be pressed out and replaced or does the whole arm need to go?
Thanks as always :thumbs:
:thumbs:
  ZMANALEX said:
Why did you not just ask a simple question in the first place without complicating things. :lol::lol::lol:
The ball joint in the compression rod is part of the rod and is not available on its own.
Alex :)
Its what I do. :p
Ah cheers. I'l drop you a pm if I am going to replace them :thumbs:
