Allan Zada Posted September 30, 2012 Share Posted September 30, 2012 Yesterday i decided to change my spark plugs, and when i removed the plug for cylinder 6 i found it was leaking oil into the plug recess. Does any one know if the large "o" seals for the recess come with the rocker cover gasket? I have a 04' DE Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 30, 2012 Share Posted September 30, 2012 Yesterday i decided to change my spark plugs, and when i removed the plug for cylinder 6 i found it was leaking oil into the plug recess. Does any one know if the large "o" seals for the recess come with the rocker cover gasket? I have a 04' DE Alan, unfortunately you will require a new cam box cover and gasket. viewtopic.php?f=157&t=57126 In stock and good to go same/next day Alex Quote Link to comment Share on other sites More sharing options...
evilscorp Posted September 30, 2012 Share Posted September 30, 2012 common problem unfortunately not too much of a pain to refit, might as well install a plenum spacer at the same time Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 30, 2012 Share Posted September 30, 2012 common problem unfortunately not too much of a pain to refit, might as well install a plenum spacer at the same time Quote Link to comment Share on other sites More sharing options...
Allan Zada Posted September 30, 2012 Author Share Posted September 30, 2012 as luck would have i have a plenum spacer already just didnt want to install it to much before the remap due to what ive read about running lean. Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 30, 2012 Share Posted September 30, 2012 as luck would have i have a plenum spacer already just didnt want to install it to much before the remap due to what ive read about running lean. Some things are just meant to be Quote Link to comment Share on other sites More sharing options...
evilscorp Posted September 30, 2012 Share Posted September 30, 2012 Having a crack at it yourself? not too hard a job same thing happened to me, altho I didn't have any problems driving around for the few months until the remap. never heard of running lean with a spacer Quote Link to comment Share on other sites More sharing options...
