adam1942 Posted September 30, 2012 Share Posted September 30, 2012 Guys what size punch do you need to remove the pins from the Brembo callipers? I assume its a 3mm or 1/8th inch? I was looking at this: http://www.toollineuk.com/product.php/s ... sn/STR565C Cheers, Adam. Quote Link to comment Share on other sites More sharing options...
Wasso Posted September 30, 2012 Share Posted September 30, 2012 You don't need a punch tool for the Zed. What I'd is press in the retaining spring plate with a screwdriver. Then whilst the pressure is off the pin get some pliers and grab the pin in the middle and slide twist the pin towards you until there's enough to grab the pin from the outside of the caliper. The retaining spring plate will still need pushing down until the pin is almost all the way out. Make sure once the pin is out the spring plate doesn't spring out as you could lose it. Once the pin is out release the pressure from the spring plate and remove it. The second pin pull out with pliers as you would the first one. Replace I'm reverse order. Tip: The holes in the pin, line those up nicely so that when you put the retaining clips through them they're easy to find. Tools needed. Wheel wrench Screwdriver Pliers Simple. Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 30, 2012 Share Posted September 30, 2012 And clean the pins once you get them out with some emery cloth, they'll be easier to get back in when you reassemble Quote Link to comment Share on other sites More sharing options...
Wasso Posted September 30, 2012 Share Posted September 30, 2012 And clean the pins once you get them out with some emery cloth, they'll be easier to get back in when you reassemble Good tip yes, I just spray them and wipe etc with WD40. Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 30, 2012 Share Posted September 30, 2012 And clean the pins once you get them out with some emery cloth, they'll be easier to get back in when you reassemble Good tip yes, I just spray them and wipe etc with WD40. What!!!!!!! ??????? You don't polish them Quote Link to comment Share on other sites More sharing options...
Chris AME Posted September 30, 2012 Share Posted September 30, 2012 And clean the pins once you get them out with some emery cloth, they'll be easier to get back in when you reassemble Good tip yes, I just spray them and wipe etc with WD40. What!!!!!!! ??????? You don't polish them I polished mine when I did mine lol Quote Link to comment Share on other sites More sharing options...
Wasso Posted September 30, 2012 Share Posted September 30, 2012 Funny enough no Mr G But something in that area will get a polish soon and be up for sale in November Talking of polishing I'm outside now polishing Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 30, 2012 Share Posted September 30, 2012 Funny enough no Mr G But something in that area will get a polish soon and be up for sale in November Talking of polishing I'm outside now polishing Meh, I'm sitting in doors again, can't even bloody drive yet Quote Link to comment Share on other sites More sharing options...
HaydnH Posted September 30, 2012 Share Posted September 30, 2012 Talking of polishing I'm outside now polishing In public! I hope you're out back hidden by fences. Quote Link to comment Share on other sites More sharing options...
Wasso Posted September 30, 2012 Share Posted September 30, 2012 Talking of polishing I'm outside now polishing In public! I hope you're out back hidden by fences. NOT that sort of polishing Mr H Quote Link to comment Share on other sites More sharing options...
adam1942 Posted October 2, 2012 Author Share Posted October 2, 2012 Brilliant guys thanks for this Quote Link to comment Share on other sites More sharing options...
