Lower Zed or leave standard?
Whazza22
Hi all,
How much difference do people find it makes to the appearance and drive of a zed by lowering? I have standard nissan alloy wheels at the moment
Thinking about taking up Tarmac's Ksport lowering spring offer which I believe lowers by 25mm all round. I find the drive quite firm as it is and don't fancy it being firmer especially with all the potholes in the road etc.
Thanks
Surely you've answered your own question there? If you don't want it to be firmer then don't lower it, especially by fitting shorter springs. Lowering springs can't magically provide the same spring rate with 25mm less travel, so they have to be slightly firmer to compensate or they'd bottom out all the time. Fully adjustable true coilovers could probably be tweaked to give a lower stance with almost OEM ride quality, but your into the thousands for those.
DB
I had eibach springs on mine, went back to stock cause the exhaust was scraping over EVERY speed bump. Actually blame them for wrecking my exhaust and having to get a new system (nothing to do with Japspeeds build quality obvs :ninja: )
Lowered is best :thumbs:
Must be true I found this on the internet -
  Some Race Car Builder said:
There are two reasons why owners lower their cars. First to enhance performance of the vehicle. This happens because, by lowering the car you also lower the center of gravity, which according to the laws of physics reduces weight transfer when turning. "Lowering springs", which are used to achieve this are usually stiffer, meaning that the spring is harder to compress. This also reduces weight transfer when turning and thus improves handling of the vehicle. The second reason why people would do such a thing, is for plain aesthetics. Many people feel that a lowered car looks better.
My concern for a road car would be how does the car react to bumps at speed, particularly during cornering - the roads in Surrey are seriously bad. Suspension is a real art - Lotus get it - they manage to get cars with a low centre of gravity, which react well to cornering forces but which are still compliant - that is not an easy thing to achieve - the combination of springs, arbs, dampers, bushes, geometry, tyres, pressures, etc.
  4RE Leather said:
  glrnet said:
I still can't make my mind up but have been eyeing up Meister's B)
So am I since Octet stuck them on and a good price:)
If I were you I'd be trying to decide exactly what's not quite right with your car's set up before you do anything else to it imho
I said eyeing not buying lol
Nothing wrong with my car its my imaginary friend who has the problem:)
:bangin:
:bangin:
You're never alone with schizophrenia :D:headhurt:
I personally like the look of a lowered Zed. :)
If you are looking for just springs, Eibach Pro-Kit would be my choice.
They are high quality, and also know how to wound progressive rate springs very well.
The problem with lowering springs is "what you see is what you get", there are no control over where the car sit.
And also, you are reusing the standard dampers (which can be 10 years old now in some cases), so they may not provide optimum performance.
If you are looking for coilovers, then coilovers like the MeisterR Zeta-S would be a good choice.
They replace the suspension with adjustable mono-tube dampers and linear rate springs.
This make weight transfer much smoother, meaning great driver confidence.
The mono-tube dampers provide better damping sensitivity and better steering response.
And the adjustments allows you to control the ride quality and bias of the suspension.
Unlike lowering springs, the ride height is adjustable so you can set the suspension to where you like it.
You might not want to too low if you have loads of speed bumps around where you life... or you want it lower for the looks.
What that mean is you have total control over the ride height and ride quality, along with the added benefit of controlling your desired ride height.
One thing I do need to bring up is that after installing coilovers (or any suspension component), you should have your alignment check and setup.
Because the best suspension in the world will drive rubbish if the wheels aren't pointing to the right direction. :)
Damn I knew I did something wrong, I only installed coilovers as I needed an alignment! :blush:
Get it done, always should be done after suspension change.
Sometime you can get away with it... but most time than not, the alignment will be out.
And the further the alignment is out, the bigger the performance difference when you get the alignment corrected. :)
Are you sure Abbey didn't do an alignment? I thought they have a 4 wheel laser tracker in house?
Edited by MeisterR
Yes it did have an alignment... I meant that instead of your comment above saying "get an alignment done if you get coilovers fitted", I did it the wrong way around and "got coilovers fitted just because I needed an alignment".
I think mine looks better lowered - but I wouldn't do it again as she bottoms out on road humps and even sometimes on catseyes (especially in Northern Ireland) unless you have the coilovers wound up to hard
(at one time I only used the top 25% of the coilover settings for spirited driving or track - but in Norn Iron had to do something to compensate for the road surface after bottoming several times!)
If I had my time again I'd leave her standard height to cope with the rubbish roads and road humps
