Zedrush Posted March 21, 2007 Share Posted March 21, 2007 Okay, my brother its abouts to buy a 350z, finally convinced him. He had as his track car a Saab 900 Turbo, spent about 18k over 5 years with Abbots Racing which produced 360bhp. It was a sleeper car and he P!ssed of a lot of people. He runs around in a Mercedes CLK 500 which is nice, so he will have a 350z as his weekend car. He is planning on spending 12k on top for body kit wheels and most importantly a supercharger. He wants to know which is better: Vortech or Stillen and where to get it from in UK fitted. I know I asked this before but I have a brain of a goldfish Quote Link to comment Share on other sites More sharing options...
Removed Posted March 21, 2007 Share Posted March 21, 2007 the search button is your friend, and moved Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted March 21, 2007 Share Posted March 21, 2007 Vortech has good mid/top end performance but misses out low down Stillen is great low down and mid and trails off higher up. + its generally a better all round kit Abbey motorsport have fitted a couple of Vortechs No one i know of in the UK has fitted a stillen, + it requires a different bonnet. . . my350z.com is your friend too. . . . Quote Link to comment Share on other sites More sharing options...
Removed Posted March 21, 2007 Share Posted March 21, 2007 Stillen is generally a better all round kit No one i know of in the UK has fitted a stillen, + it requires a different bonnet. . . that's the first time I hear the Stillen is a better kit than the Vortech tbh. Stillen has major heat soak problems, MrF has got one (latest stage fitted) and his best 1/4mile was 13secs... without considering the ugly bonnet bulge! IMO the Vortech is a better package Quote Link to comment Share on other sites More sharing options...
Pingu2 Posted March 21, 2007 Share Posted March 21, 2007 how about the ati procharger? I have read that it's good?.. although I think the oil in it needs changing every 3k miles which could get tiresome.. Quote Link to comment Share on other sites More sharing options...
Removed Posted March 21, 2007 Share Posted March 21, 2007 if you get yrself an ATI, you love playing with fire (and your internals ) Check out the TDI blog of that SC failure... Quote Link to comment Share on other sites More sharing options...
Pingu2 Posted March 21, 2007 Share Posted March 21, 2007 well I will be getting Vortech when I get one (next year maybe) - seems the safest/easiest and one of the best options.. Quote Link to comment Share on other sites More sharing options...
rickya Posted March 21, 2007 Share Posted March 21, 2007 Agree with Val (for once! ), Vortech is better than Stillen. Though saying that if you dont want to go mental with power then the Stillen quite good as Stage 1 kind of supercharger. Quote Link to comment Share on other sites More sharing options...
Zedrush Posted March 21, 2007 Author Share Posted March 21, 2007 How much power can you get from a vortech? Sumo are running one that is 480bhp I thinks its twin turbo Quote Link to comment Share on other sites More sharing options...
captint Posted March 21, 2007 Share Posted March 21, 2007 What about a Novidem Quote Link to comment Share on other sites More sharing options...
neo Posted March 21, 2007 Share Posted March 21, 2007 as used on the black 350z as a test bed by nissan uk Quote Link to comment Share on other sites More sharing options...
Removed Posted March 21, 2007 Share Posted March 21, 2007 How much power can you get from a vortech? Sumo are running one that is 480bhp I thinks its twin turbo vortech 390ish Sumo have a custom SINGLE HKS turbo jobbie ~ 500hp Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted March 21, 2007 Share Posted March 21, 2007 if you get yrself an ATI, you love playing with fire (and your internals ) Check out the TDI blog of that SC failure... I think this is now nolonger the case. The ATi is much better understood that say 12-24 months ago (rather like GReddy in the early days, it suffered with its reputation going before it). The real problem with ATi is that it was shipped with no timing control, so it run with stock advance and this was a recipe for disaster. Now, couple it with a piggy back (UTEC, Unichip) to pull some most timing at peak torque gradually adding a tad more advance to redline and all will be well. Its in the tune There are pros and cons to all units. Stage 1 Stillen has no intercooler and thus heat soak is a major issue - less so with other Stages. Then there's the bulge - but you do get earlier wind-up of boost than Vortech. But in a normal situation when you're on the gas (4500-6500rpm), you're in the Vortech boost range most of the time At least one of the Stillen packages comes with an engine warranty - which may be a big plus. Stillen is not tuneable - Vortech is; even although they both use the SplitSec box Quote Link to comment Share on other sites More sharing options...
Removed Posted March 21, 2007 Share Posted March 21, 2007 heat soak is still a problem, in the stillen tbh, Mike has the latest stage on his Z and can't do a couple 1/4 without suffering from heat soak... I have to admit I don't see many people going for a SC on the US boards anymore... they all go TT! Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted March 21, 2007 Share Posted March 21, 2007 I have to admit I don't see many people going for a SC on the US boards anymore... they all go TT! True,but by the same token, there is a very high percentage of built motors. Build your motor and TT - that is the best solution of all at the highest £££ Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted March 21, 2007 Share Posted March 21, 2007 A fairly typical Vortech plot (mine) - add about 15% to get flywheel numbers Quote Link to comment Share on other sites More sharing options...
rickya Posted March 21, 2007 Share Posted March 21, 2007 Theres alway the option of 75bhp to 100bhp shot of nitrous on std internals & ECU? Cheaper & easier & maybe less chance of blowing up the engine. (ps saying that I have seen a you tube video of the above happening on a qtr mile run in the US!!!) Quote Link to comment Share on other sites More sharing options...
Sarnie Posted March 21, 2007 Share Posted March 21, 2007 Stillen is generally a better all round kit No one i know of in the UK has fitted a stillen, + it requires a different bonnet. . . without considering the ugly bonnet bulge! What like this one? http://www.pistonheads.com/sales/143410.htm Quote Link to comment Share on other sites More sharing options...
sl114 Posted March 21, 2007 Share Posted March 21, 2007 I quite like that Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted March 21, 2007 Share Posted March 21, 2007 thats interesting sarnie. . . i might go and check it out. . . its not too far away from me. . .would be interesting to see what its like if they dont mind me tyre kicking. . . jamie Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted March 22, 2007 Share Posted March 22, 2007 Yep, went and checked it out today. Quite a nice motor. Had an interior re-trim in alcantara all across the headlining and the doors, and some 'luxury; floor carpet etc. Wasnt to my liking, didnt go with the tan seats, if they were re-done would look better. It has the Stillen on it. Personally i think the bonnet is F-ugly, very bodge, but ive seen them smoothed in and they can look good. Driving it, to be honest, i couldnt REALLY boot it,floored it in 2nd and did seem to have a nice pull to it, seemed to smooth out the engine, seemed abit morelinear, but that could be the resistance of the super charger taking out the 'jerkyness' when ya put ya food done. To be honest, i wasnt that impressed. It didnt feel significantly quicker than my own Z, though admittedly, i wasnt able to take it past 55mph and as it had a standard airbox didnt even get to hear any exciting whine which stillens are supposed to have. Its gotta be a turbo. . . . . . . Quote Link to comment Share on other sites More sharing options...
Sarnie Posted March 22, 2007 Share Posted March 22, 2007 He let you drive it??? Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted March 23, 2007 Share Posted March 23, 2007 You didn't give it a proper test because there is no comparison between supercharged and stock performance - not at all Quote Link to comment Share on other sites More sharing options...
Removed Posted March 23, 2007 Share Posted March 23, 2007 bloody hell you must be deaf if you didn't hear the stillen whine! it sounds as if someone is murdering a small child under that bonnet! Quote Link to comment Share on other sites More sharing options...
live2themaxuk Posted March 23, 2007 Share Posted March 23, 2007 it had a stock airbox so i assume that is why i didnt hear it, took it up to about 4500 rpm he was next to me i could blat it even if i wanted too Quote Link to comment Share on other sites More sharing options...
