Yarlsberg Posted September 27, 2012 Share Posted September 27, 2012 Does anyone know if there is already a sheet listing steps to go through to change over seats (order for undoing nuts, disconnecting wiring etc) Am complete novice so don't want to spoilt connections set off airbags etc etc cheers Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 27, 2012 Share Posted September 27, 2012 1. Disconnect battery 2. Take off plastic covers over the bolts 3. Remove bolts 4. (Tricky bit) unclip wiring for airbags, electric seats and seatbelts all are under the seats, you will have to cut some plastic clips too 5. Remove seats I may have some pics somewhere I will have a look tomorrow Obvious point, make sure seats are in the right position to get to all the bolts before you disconnect the battery Quote Link to comment Share on other sites More sharing options...
Yarlsberg Posted September 27, 2012 Author Share Posted September 27, 2012 also I am fitting seats from an 03 into my ' 08 Gt Roadster. On mine the seats automatically move forward when the roof is being lowered. Can anyone who has a pre-facelift roadster model confirm whether theirs also do the same. Quote Link to comment Share on other sites More sharing options...
Yarlsberg Posted September 27, 2012 Author Share Posted September 27, 2012 thanks Dave- do you lift the seat up off its mounts to unclip the wiring or do it all before attempting to takethe seat up Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 27, 2012 Share Posted September 27, 2012 The seats can be lifted a little so you can get your hands under and undo the clips. Once you know where they are you can actually unclip them without even moving the seats. I don't have a roadster though, can't help with the other question sorry. Good luck Quote Link to comment Share on other sites More sharing options...
Yarlsberg Posted September 27, 2012 Author Share Posted September 27, 2012 nice one thanks a lot. Quote Link to comment Share on other sites More sharing options...
KC350Z Posted September 28, 2012 Share Posted September 28, 2012 also I am fitting seats from an 03 into my ' 08 Gt Roadster. On mine the seats automatically move forward when the roof is being lowered. Can anyone who has a pre-facelift roadster model confirm whether theirs also do the same. Mine is a 53 jdm roadster but yes on mine only on the passanger side tho but drives side might do it but as im a short ass it does not need to as move so roof does not hit the seat will put it back same as the other and find out Quote Link to comment Share on other sites More sharing options...
Yarlsberg Posted September 28, 2012 Author Share Posted September 28, 2012 cheers sounds like it is the same as mine- and a bit odd when you think about it as what's the point of it just doing it on one side?! Quote Link to comment Share on other sites More sharing options...
KC350Z Posted September 28, 2012 Share Posted September 28, 2012 cheers sounds like it is the same as mine- and a bit odd when you think about it as what's the point of it just doing it on one side?! only thing i can think is its something to do with the auto forward back button behind the seat for the glove box as drivers seat dont have it only the normal switchs Quote Link to comment Share on other sites More sharing options...
