Rear Speakers
taffyjason
Take driver and passenger strips off where the kick panels are.
Now take off the quarter plastics behind seat and beneath quarter windows.
Take off BOSE sub cover.
You may need to loosen the central tunnel two bolts between driver and passenger seat.
Now take off lower rear section, you'll need to disconnect the 12v socket and parts of the passenger cubby.
You can now take off the piece of plastic you want to remove that stretches from behind the driver and passenger seats.
The problem is you have to remove these plastics in this order as each panel of plastic holds another in place :thumbdown:
That's quite a ball ache for something that looks initially easy!
