JamesGood Posted September 14, 2012 Share Posted September 14, 2012 Both inside and external handles on my drivers door have stopped working, I've looked between the gap in the window and noticed the rod isn't moving as I pull on the external handle. I'm sure the fix is easy however... I can't get the door card off because the door is shut! I've tried everything I can to get it off in situ but no joy. Has anyone else had this, is there a way of pulling the rod or opening the door any other way before I take a saw to my doorcard? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 14, 2012 Share Posted September 14, 2012 can you get in through the boot? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 14, 2012 Share Posted September 14, 2012 ignore that, just realsied you've got into the car, but can't open the door to take the card off. think you might be a bit fubar on this Quote Link to comment Share on other sites More sharing options...
JamesGood Posted September 14, 2012 Author Share Posted September 14, 2012 Ha, thanks fella. Success though! I just managed to get in with the trusty old coat hanger! Now the door card is off I can have a look to see what's wrong with the lock. It's very weird though, nothing's really broken, it just seems that when the door is locked then unlocked you can open the door fine but if its locked, then you try pulling the handle it seems to dislodge something and when you unlock the door you cant open it until you tug on the rod, then open from the inside. For now I guess I just have to remember not to pull the handle before unlocking it...! Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 14, 2012 Share Posted September 14, 2012 could things be sticking, i.e when you pull on the handle things are being left in place? would spraying a liberal amount of wd40 on the mechanisms help free it all up. or some good 3 in 1 oil. Quote Link to comment Share on other sites More sharing options...
JamesGood Posted September 14, 2012 Author Share Posted September 14, 2012 It's worth a squirt, though it does all appear very smooth and free. I'll add a bit in there anyway Quote Link to comment Share on other sites More sharing options...
