Airbox foam insert?
jonst205
Question is, does it make any difference to the noise with the foam removed? Gotta love a bit of induction noise if available, the zed is pretty muted on the induction front as standard :dummy:
You read my mind B) The only concern I have is that with it removed it actually disrupts the airflow into the stack as you have a big pocket for air to sit in. However I think it should be fine as, especially on throttle, the engine is actively pulling the air in at a fair old rate. I'm taking my old pre-06 box out shortly so will see if it has the same insert arrangement.
