Keyser's Mini Adventure. Update 30th June
Keyser
Very jealous of your setup, oh the fun I could have with a sandblaster.
They make a mess!!! Sand Blaster = Cheap
Compressor to run it = $$$$$ :scare:
The wheels look awesome. You must be the favourite parent by now lol
Only done one so far :wacko: Not sure about fav parent - Mrs Keyser gives em pocket minet :lol:
Can you be my dad?
But I am your father Luke -
May the force be with you!
I knew I was adopted but I'd never have guessed you were my dad!
I'd prefer Bob to be my dad :stir:
:lol:
After I sent you the mag and everything!!! Fine be like that :p
:lol:
can you build one for my 16 and a half year old as well :lol:
Errr not before they are 18 at least :lol:
But Chris has the fun toys and The Bitch!
Thanks BBK or should i say son
Ha Ha RT, Jag ownership and the battle against rust seem to go hand in hand.
Very interested in this Keyser. Every part I strip off the Jag is going to need refurbing. Starting to realise what a big project I've taken on. Found a company that will chemically strip and coat the body shell, but it's all the small bits that need blasting and etch priming straight away. what CFM is your compressor? Keep up the good work :thumbs:
Hi mate missed the question :blush:
Spec on myine is -
  • 14cfm displacment - cast iron, twin cylinder compressor pump
  • 200 litre air receiver (CE certified)
  • 3hp motor, 230v, 1ph continuously rated with overload protection
  • 10bar (150psi) maximum working pressure controlled by a fully automatic pressure switch.
  • Specification also includes safety valve, pressure gauge, air outlet valve & drain tap.
  • Application - professional automotive/industrial
It was the biggest I could get without needing 3 phase power - its on it's own 30AMP supply - only just up to the sand blaster but great for spraying and all the other stuff :thumbs:
'Ere, pull your finger out ;):stir:
Anything else happening on the Mini front? I've been loving this! :teeth:
:p
:lol:
Been mad for the last 2 weeks and project K (the other Zed) has taken some time - done a few bits and hope to get some more done tomorrow with pics for ya :thumbs:
:p
:lol:
Awesome, look forward to it fella!
Sorry for the delay folks, been a busy boy of late lots of stuff happening but an update at last :thumbs:
Some new bits arrived
Then I started sorting out the best of the parts so I can prep them for paint
I did sand blast the sub frames
They are in good nick so just did the loose paint and rust
Then I stripped the other rear hub
Then onto the front hubs - never been apart from new is my guess
Calliper
Rusty but the pistons are free and the bleed nipple came free
Really
Got em out though
The I came across the drive shaft nut and this was a tough little nut to crack!!!
600mm Breaker bar
It just laughed at me as I hung from it!
So I went to get my destroyer the 1m breaker bar - but I lent it to my mate :doh:
I swear I heard the nut laugh again - so to copy Mr Marcel Wallace I called some hard hitting home boys to get medieval on its arse with a blow torch :lol:
Not F******g laughing now are ya!!!
:kicking:
One for Buster
you can undo a rusty bolt without snapping it :p
the other calliper
more bits
Stay tuned for the next exciting episode ......................
WARNING!!!
THE FOLLOWING POST CONTAINS PICTURES OF MY WIFE GETTING DOWN AND DIRTY!!!!
Well don't say I didn't I warned you!!!!
Back on the Mini again today :yahoo:
We started by stripping the front hubs
Got the big guns out on the stubborn bolt 1" Drive socket set!! MUHAAAAAAA
Then stripped some more bits for cleaning
The wife getting her hands dirty
Now she is just getting dirty :blush:
yes that's Mrs Keyser in the sand blasting chamber :thumbs:
As the bits go through they come out clean
Pile of bits waiting to go through
The done bits pile grows
The bottom arm was cleaned with a wire wheel the top with a sand blaster
Before and after shots
All done by 7:30pm
Also got the wheel back from repair - it is one of the 12" set I got cheap after blasting I noticed a small dent in one, minor and not actually causing a problem but a mate was taking his Supra wheel in for repair so we thought we could get a deal on two being done and we did :thumbs:
Round wheels again :)
Paint this week then :thumbs:
Look like its all good in the keyser residence again :winks:
How did you manage to turn her around so fast.. oh sly one :lol:
I told her if she didn't buck her ideas up I wouldn't build her another Zed ;)
