Keyser's Mini Adventure. Update 30th June
Keyser
:wave:
First job today was to shorten and shape the legs that go into the OEM mounts
Got to use one of my Christmas presents as well :thumbs:
Got the mounts off set to move the seats closer to the middle so they clear the door
Bolts welded into the other seat runners
Next problem was the OEM rear clip, it is to high so the seat can rock an inch up before it engages
So I cut it down and re welded it :thumbs:
Drivers side seat sorted
The previous owner had welded a plate in presumably for his bucket seats but it was in the way so I could not fit the OEM passenger side seat clip so I had to cut it out.
As you can see it did a bit of damage so I'll weld that up next time and get the passenger seat finished.
Stay tuned for the next exciting episode ......................
Hi as I'm getting grief for not doing the Mini from a wife - Not my wife but a wife (you know who you are Mrs Buster) Thought I'd better show you lot I'd done a few bits.
First job was the whole in the floor from cutting the old seat mount out
Passenger seat in and sorted
ZedShed in a mess :blush:
ZedShed sorted :)
Finish this vent that had been plated
Need to put this tube in (cut from the other shell)
All cleaned up
Tube welded in
Clean up the welds underneath
Wire wheel to remove all the crud
All done (Where did that green come from :lol: )
All the plates and bare metal got a coat of Zinc rust primer
Then the whole underside got a coat
Leave that to dry now :thumbs:
When ever it's ready keep an eye on here.
I would caution that I only have one air fed mask - Bob has managed about 15 minutes with the fly mask on while I'm spraying clear coat then you start to smell it but clear coat is bad for hanging in the air basecoat is is much cleaner when sprayed (well it is for me anyway) :lol:
But welcome to come along and see how not to do it :)
