How to - Change Z badges (and others)
jep350z
Learning from the advice in this thread, I completed the de-Nissan-ing of my Z this morning.
I used a hairdryer to heat up the original badge for a few minutes to soften the glue...
...and then used a piece of fishing line behind the badge to start sawing through the glue. I started at one of the corner bits of the Nissan bar and only brought the line in an inch or so, before I could then just lift and remove the badge with my fingers.
Cleaning up most of the remaining glue left it looking like this:
The replacement badges I'd chosen were from the same eBay seller in Taiwan I'd bought my LED sidelights from. These use the same design as the side badges, which I really like:
They have 3M tape on the reverse covering the entire badge:
And fitted look like this close-up...
...and like this from further away:
I also planned to replace the rear badge, and marked it up with masking tape so I could get the replacement in exactly the same place.
However, the replacement rear badge didn't have the right curvature to fit properly, but fortunately the old badge came off and cleaned up so well (with a bit of white spirit and a couple of coats of Mer) that I decided I preferred the clean look anyway.
Undecided as to whether to remove the 350Z badge as well - what do you think?
James
  • 1 month later...
