L4V15 Posted September 5, 2012 Share Posted September 5, 2012 I'm picking up my new 06 facelift 350z on the 12th but I think the drivers window needs re learning to know where the top is etc so that it stops at the top and drops down when opening the door. Is this just a case of doing an ECU reset using the peddle dance? Anybody know if this works for resetting the windows? Also I really wanted one that came with a Sat Nav built in, but unfortunately had to go for this one without the sat nav. How easy is it to get hold of a sat nav and install it properly? Major job or easy? Any help would be great. Cheeers! Quote Link to comment Share on other sites More sharing options...
CrustyCrab Posted September 5, 2012 Share Posted September 5, 2012 To reset the windows you need to get the door card off and there is a button etc. Read this.... viewtopic.php?f=35&t=30870&start=0 Very useful Quote Link to comment Share on other sites More sharing options...
CrustyCrab Posted September 5, 2012 Share Posted September 5, 2012 You may only need the bit at the end of the PDF guide Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 5, 2012 Share Posted September 5, 2012 Retro fitting a satnav is a pretty big job as there is a lot of wiring and bit required, a lot of work just get a tomtom etc Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted September 5, 2012 Share Posted September 5, 2012 reset procedure: fully down keeping switch pressed for a few seconds, then fully up keeping switch pressed for a few seconds and it's done simples and same on most cars AFAIK Quote Link to comment Share on other sites More sharing options...
L4V15 Posted September 5, 2012 Author Share Posted September 5, 2012 Hell! That easy? Awesome. I'll give it a shot on the 12th. Cheers for that Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 5, 2012 Share Posted September 5, 2012 reset procedure: fully down keeping switch pressed for a few seconds, then fully up keeping switch pressed for a few seconds and it's done simples and same on most cars AFAIK I thought it was fully up with button released Quote Link to comment Share on other sites More sharing options...
L4V15 Posted September 5, 2012 Author Share Posted September 5, 2012 Is it? Ok, I'll try both. Thanks again! Quote Link to comment Share on other sites More sharing options...
L4V15 Posted September 5, 2012 Author Share Posted September 5, 2012 The problem the car has at the moment is that when using the auto up on the drivers side, the window drops back down again once it gets to the top, thinking something is it the way, not knowing it's got to the top if you know what I mean Quote Link to comment Share on other sites More sharing options...
glrnet Posted September 5, 2012 Share Posted September 5, 2012 Reset should solve that The problem the car has at the moment is that when using the auto up on the drivers side, the window drops back down again once it gets to the top, thinking something is it the way, not knowing it's got to the top if you know what I mean Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 5, 2012 Share Posted September 5, 2012 There is a good guide on here, door card off bit of fiddling and its good Quote Link to comment Share on other sites More sharing options...
L4V15 Posted September 5, 2012 Author Share Posted September 5, 2012 Ok great. So long as it's easily fixed. I'll try all the methods and I'm sure one of them will work. Cheers all! Quote Link to comment Share on other sites More sharing options...
L4V15 Posted September 13, 2012 Author Share Posted September 13, 2012 Hmm, tried both and no luck. Any other ideas anybody? Steve Quote Link to comment Share on other sites More sharing options...
