robin c Posted September 3, 2012 Share Posted September 3, 2012 I have a set of Eibach spacers in my garage which were meant to go on the 313, don't suppose they also fit 370z running normal 19in rims? The fronts are 20mm and the rears are 25mm. Quote Link to comment Share on other sites More sharing options...
Jay Posted September 3, 2012 Share Posted September 3, 2012 I have a set of Eibach spacers in my garage which were meant to go on the 313, don't suppose they also fit 370z running normal 19in rims? The fronts are 20mm and the rears are 25mm. I would think so mate Quote Link to comment Share on other sites More sharing options...
Ebized Posted September 3, 2012 Share Posted September 3, 2012 From actual experience, they are fully inter-changeable Without repeating myself too many times there is an issue with some (if not most) 370 wheels that will not allow the OEM 19" wheels to sit flush on 20mm spacers due to the length of the protruding hub studs. In the last pic the recess areas you see in the front wheels means the little bolt and spacer washer on each front hub to fit fine but you can see how the stud locations on a wider diameter clash with the raised section (with the "NISSAN" wording) that is only about 2/3mm deep Thee is no such problem with the rear wheels. Quote Link to comment Share on other sites More sharing options...
robin c Posted September 3, 2012 Author Share Posted September 3, 2012 Thanks for the tip & detailed explanation. Will have to wait and see what the outcome is! Not a big deal as I can pick a set up next time I am out in New Jersey along with a decent exhaust! Quote Link to comment Share on other sites More sharing options...
robin c Posted September 13, 2012 Author Share Posted September 13, 2012 Silly question, but has any one put 25mm on the fronts and 20mm on the rear as I am guessing the stud issue wont be problem on the rear alloys. Will this look nasty or worst still make a mess of the balance of the car? Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted September 13, 2012 Share Posted September 13, 2012 Not a silly question at all and one I myself was ignorant of until Zedmanalex mentioned it in a post. Makes sense 25 on the front and 20 on the back if your keeping stock sizes as I am guessing this brings the fronts out to almost the same stance as the rears. Quote Link to comment Share on other sites More sharing options...
