Hissing from engine
jell36
Probably just the PCV valve making that noise. It is on the off side front of the engine on the rocker cover and has a hose coming out of it. I believe that they are meant to hiss as it's the air pressure from the crankcase being relieved and put back into the plenum.
Brilliant, many thanks. I had read that there was a hiss that was normal on the US forums but wasn't sure if this was it. Thanks for clarifying.
