Gearbox oil
Shel
unfortunately if you have an '04 Zed, your first to second shift is probably never going to be that slick. Genuine Nissan gearbox oil and Molyslip additive will help, but it's unlikely to completely cure the problem.
:pmzmanalex: does the genuine oil and the Molyslip
DB
I have a 2004 car, with nearly as many miles on as yours. I noticed that the gearbox was slightly notchy from 1st-2nd, despite having had castrol saf x-o put in it a year ago by previous owner. I switched it for genuine Nissan transmission fluid with molyslip and it's now perfect, even when cold. :pmzmanalex: as I got mine from him with great service and advice. Also probably worth changing the diff oil; the old stuff was a bit minging and it definitely feels better as a result :thumbs:
Just to reiterate JJT's comments, I've also just had my gearbox and diff oil changed, ordering the oils and Molyslip from Zmanalex.
In fairness my gearbox was pretty good before, though now it just feels so much better, effortless changing through all gears hot or cold. Hands down the best improvment to cost gain I've done to my Z.
+1 :thumbs::pmzmanalex: Get some oil from him, change it, feel the difference...
  • 4 months later...
