A problem with my car.
hellozaizai
Nissan 350Z. It got caught up in a flood and was soaked up to the hood. It was taken for a scan and the scanner couldn't connect to the ecu. So what next do i do as i couldn't get a scan result. Does the tool named ********************used for me ? If you know please tell me . Thank you.
Link removed
Another thread inquiring about OBDII readers? Fine...
In short, no. None of the OBDII readers you've posted will be able to read anything on your car if you've already tried another tool. They're all the same really, and the flood damage you're describing could very well be terminal if all the electrics are goosed.
As what Dan says :thumbs:
However if you require any electrical stuff like: ECU, BCM, IPDM, Fuse Boxes etc then no drama as I have them all in stock :thumbs:
All preowned and still on a working car that is about to be dismantled.
Alex. :)
