theminiking Posted August 23, 2012 Share Posted August 23, 2012 Hi guys! New to Zeds and really enjoying my first week of ownership .. But perhaps a little too much? So far my fuel consumption seems bit too good to be true?? Does anyone know if the zed uses a fuel flow transmitter for it's mpg calculations or does it use a standard fuel flow and injector pulse timing to work it out which could explain my miraculous mpg (47 on a long run! : headhurt: ) as I have 550cc injectors. Laurie. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 23, 2012 Share Posted August 23, 2012 AFAIK it uses injector pulse, so having larger injectors will give the effect you are seeing. No way in hell you are getting 47MPG Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 23, 2012 Share Posted August 23, 2012 Is it an import - if so it could be kml you are seeing? Quote Link to comment Share on other sites More sharing options...
S1 HNK Posted August 23, 2012 Share Posted August 23, 2012 47mpg from a Zed....its what dreams are made of Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 23, 2012 Share Posted August 23, 2012 Is it an import - if so it could be kml you are seeing? He's running larger injectors Col, 550CC vs 290/330CC of stock (depending on how you measure them). So if the car isnt boosted then pulses will be shorter than stock so the car thinks its using less fuel OP - post up your car details Quote Link to comment Share on other sites More sharing options...
theminiking Posted August 23, 2012 Author Share Posted August 23, 2012 That'll explain it! Was about to go and ditch my diesel commuter it was so good! Thanks guys! Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 23, 2012 Share Posted August 23, 2012 That'll explain it! Was about to go and ditch my diesel commuter it was so good! Thanks guys! What are the specs of your car and why are you running larger injectors? Is it turbo/supercharged? Quote Link to comment Share on other sites More sharing options...
theminiking Posted August 23, 2012 Author Share Posted August 23, 2012 I believe it was Dorians old Z. 54 plate GM, Vortech supercharger, Kinetix plenum and cats, Nismo exhaust, Zeitronix ZT2, 19" LMGT4s and loads of fun! Still getting used to it after my previous S14a and I'm sure I'll have alot more questions over the following months. Good to see the community here is as good as the SXOC Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 23, 2012 Share Posted August 23, 2012 That will expalin it then. Yes you are using a lot more fuel than the trip computer thinks Quote Link to comment Share on other sites More sharing options...
Darren-B Posted August 23, 2012 Share Posted August 23, 2012 Plus the range will be out, when I fill my tank the range claims over 700 miles sometimes My average since I`ve been SC`d is 31mpg Running 600cc on mine Quote Link to comment Share on other sites More sharing options...
Ian Posted August 23, 2012 Share Posted August 23, 2012 Plus the range will be out, when I fill my tank the range claims over 700 miles sometimes My average since I`ve been SC`d is 31mpg Running 600cc on mine I had that with mine aswell. I had less than 1/4 tank left & the DTE was 300 miles Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 23, 2012 Share Posted August 23, 2012 Plus the range will be out, when I fill my tank the range claims over 700 miles sometimes My average since I`ve been SC`d is 31mpg Running 600cc on mine I had that with mine aswell. I had less than 1/4 tank left & the DTE was 300 miles Does the fuel level still show the right thing? I'm sure mine used to go up and down if you booted it for a bit and then went back to driving sedately, somehow being linked to fuel usage. So if it thinks you are using sod all, it could say you have loads of fuel left when really you have nothing Quote Link to comment Share on other sites More sharing options...
Ian Posted August 23, 2012 Share Posted August 23, 2012 Plus the range will be out, when I fill my tank the range claims over 700 miles sometimes My average since I`ve been SC`d is 31mpg Running 600cc on mine I had that with mine aswell. I had less than 1/4 tank left & the DTE was 300 miles Does the fuel level still show the right thing? I'm sure mine used to go up and down if you booted it for a bit and then went back to driving sedately, somehow being linked to fuel usage. So if it thinks you are using sod all, it could say you have loads of fuel left when really you have nothing It showed permanently empty Was a lot of fun judging fuel levels when I had no centre gauges & had to rely on the fuel gauge Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 23, 2012 Share Posted August 23, 2012 You'd be better off with a float in the fuel tank sticking out behind the seats Quote Link to comment Share on other sites More sharing options...
Darren-B Posted August 24, 2012 Share Posted August 24, 2012 The level sensor in the tank is very delicate. Ian you probably knocked yours when doing the pump or frs, mine works just fine. Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 24, 2012 Share Posted August 24, 2012 Plus the range will be out, when I fill my tank the range claims over 700 miles sometimes My average since I`ve been SC`d is 31mpg Running 600cc on mine Is that what you get or what the trip shows? I managed 18 mpg on the drive back from AME yesterday Quote Link to comment Share on other sites More sharing options...
Ian Posted August 24, 2012 Share Posted August 24, 2012 The level sensor in the tank is very delicate. Ian you probably knocked yours when doing the pump or frs, mine works just fine. The empty bit was a joke My level worked fine, it just emptied tanks of fuel at an alarming rate Quote Link to comment Share on other sites More sharing options...
Darren-B Posted August 24, 2012 Share Posted August 24, 2012 The level sensor in the tank is very delicate. Ian you probably knocked yours when doing the pump or frs, mine works just fine. The empty bit was a joke My level worked fine, it just emptied tanks of fuel at an alarming rate Yes I can do a 1/4 tank in 15minutes on a good day Plus the range will be out, when I fill my tank the range claims over 700 miles sometimes My average since I`ve been SC`d is 31mpg Running 600cc on mine Is that what you get or what the trip shows? I managed 18 mpg on the drive back from AME yesterday No I don`t get 31 When we done Wales in May I avg 27 on the way up, & 23 thoughout the entire weekend. Since then I havn`t bothered working it out, Just fill it up when it needs it Quote Link to comment Share on other sites More sharing options...
glrnet Posted August 24, 2012 Share Posted August 24, 2012 Best policy with a Zed The level sensor in the tank is very delicate. Ian you probably knocked yours when doing the pump or frs, mine works just fine. The empty bit was a joke My level worked fine, it just emptied tanks of fuel at an alarming rate Yes I can do a 1/4 tank in 15minutes on a good day Plus the range will be out, when I fill my tank the range claims over 700 miles sometimes My average since I`ve been SC`d is 31mpg Running 600cc on mine Is that what you get or what the trip shows? I managed 18 mpg on the drive back from AME yesterday No I don`t get 31 When we done Wales in May I avg 27 on the way up, & 23 thoughout the entire weekend. Since then I havn`t bothered working it out, Just fill it up when it needs it Quote Link to comment Share on other sites More sharing options...
