garygttdi Posted August 22, 2012 Share Posted August 22, 2012 Its years since I did any spannering, too old and spoilt these days for that sort of thing, however it occurs to me I could spend more on the brakes if I did the installation work myself. It would be on my drive so nothing exotic in terms of facilities. From memory the biggest if issue is getting the calliper bolts undone and then the screw that holds the rotor to the hub, is this correct or should I play safe and let the Garage do it. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted August 22, 2012 Share Posted August 22, 2012 i done mine on the driveway was pretty straight forward read some of the write up guides and familarise yourself before you give it a go Quote Link to comment Share on other sites More sharing options...
evilscorp Posted August 22, 2012 Share Posted August 22, 2012 There is no screw that holds the rotor on(if i remember correctly) just the caliper bolts and something to push the cylinder bk is the only tricky parts Quote Link to comment Share on other sites More sharing options...
buzz62 Posted August 22, 2012 Share Posted August 22, 2012 just done my fronts new discs and pads , really rather easy on the Z Quote Link to comment Share on other sites More sharing options...
SteveW Posted August 22, 2012 Share Posted August 22, 2012 Just make sure you clean up the hub properly and check the run out of the disks at the largest diameter with a DTI to prevent any future DTV issues. Runout limits for front are 0.05mm or 2 thousandths of an inch. Rears are 0.07mm or just under 3 thousandths of an inch. DTV usually shows up after a few thousand miles. Apart from that it's easy. Wheels off, calipers off push pistons back can be done by hand just a bit fiddly with the 4 pots on the front. Tie caliper out of way so brake line isn't stretched. Remove disk, clean up hub. Fit new disk, measure runout with disk in all 5 positions put disk on in position with lowest run out. Bolt caliper back on wheels on job done. Disks are held on by the wheels no little grub screw to slacken. Quote Link to comment Share on other sites More sharing options...
garygttdi Posted August 23, 2012 Author Share Posted August 23, 2012 Thanks Guys Quote Link to comment Share on other sites More sharing options...
Wasso Posted August 23, 2012 Share Posted August 23, 2012 The caliper bolts as you mention could be very tight so have yourself handy a breaker bar. Did mine on the drive also, saves paying extortionate prices for a garage to undertake. Edit : whilst the wheels are off give them a good clean up and seal them with appropriate sealants to make future cleaning a breeze Quote Link to comment Share on other sites More sharing options...
jumping350 Posted August 23, 2012 Share Posted August 23, 2012 and dont over tighten the pin bolt when you put it back to do up the calliper ..it shears if you do Quote Link to comment Share on other sites More sharing options...
Daryl Posted August 23, 2012 Share Posted August 23, 2012 I did all of my discs and pads last year. Took me a while,mainly because I faffed abit and the caliper bolts were abit of a pain. If you have an extendible wheel brace, I found if you cut the cap off the rubber handle, a rachet handle sits nicely in the there,so you have a breaker bar. Makesure the caliper bolts are done up tight too,maybe put a small amount of weak thread locker (loctite or similar) on the treads. Its well worth the small amount of hassle though,as the sense of achievement is huge. Quote Link to comment Share on other sites More sharing options...
CJ. Posted August 23, 2012 Share Posted August 23, 2012 If you have an extendible wheel brace, I found if you cut the cap off the rubber handle, a rachet handle sits nicely in the there,so you have a breaker bar. Good top tip that Quote Link to comment Share on other sites More sharing options...
jumping350 Posted August 23, 2012 Share Posted August 23, 2012 or put the car wheels on full lock thats what i did plenty of room then Quote Link to comment Share on other sites More sharing options...
Wasso Posted August 23, 2012 Share Posted August 23, 2012 or put the car wheels on full lock thats what i did plenty of room then +1 Quote Link to comment Share on other sites More sharing options...
