Nico Posted August 22, 2012 Share Posted August 22, 2012 Hi all, I'm looking to wrap my door sills with DiNoc carbon fibre vinyl and had some questions with regards to wrapping. I currently have the following: DiNoc vinyl wrap heat gun Hard plastic squeegee card Craft Knife (for cutting the "Z" logo out) I just wanted to ask how I should prepare the surface of the sills for wrapping? Should I sand them a bit first to get rid of the gritty texture? should I get some surface primer as well help with the adhesive vinyl? Or is it simply a case of just giving the surface a good clean and then wrap away? I'm looking to get the same look as the 4th post down in this thread http://www.350z-uk.net/forum/viewtopic.php?f=26&t=63990 Many thanks! Nico Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 22, 2012 Share Posted August 22, 2012 I would say just give them a really good clean, if you sand them down you are making it a one way process, if you wrap the vinyl round underneath enough you wont need extra adhesive either Remember the sills will be covered up 99.9% of the time so no need to worry too much! Quote Link to comment Share on other sites More sharing options...
