jonst205 Posted August 16, 2012 Share Posted August 16, 2012 Hi all, just trying to get on top of my 2004 Z. There is a little 'vagueness' in the steering that I'd like to solve - typically you can move the steering wheel a degree or two in either direction before the tyres respond, and the car does bumpsteer a little bit. This really robs you of confidence in what the car is doing. There are no knocks are other noises that would make me think banana arm at this point. In previous cars I've had with similar issues, it has always been wear in the track rod - is this typical on the 350? The tracking is a little out so I think a previous owner may have used the kerbs as a parking aid I see I can fit a complete set of tie rods & track rods fairly inexpensively, anyone suggest otherwise? Cheers, Jon Quote Link to comment Share on other sites More sharing options...
Bry Posted August 17, 2012 Share Posted August 17, 2012 You could fit a set of Megan racing Track rods + ends both of which are adjustable to give you more lock and eliminate bumpsteer. Quote Link to comment Share on other sites More sharing options...
