Air in Clutch fluid line? or clutch?
Wayner6
Hi Guys,
just seeing if anyone can help me pinpoint an issue im having.
2003 gt 350 uk
had the issue first last night where i couldnt shift into gear easily.
clutch is currently feeling really soft and has a really low biting point, i can press it all the way down to change but a slight release and car moves..
also took for a test round the block noticed that i could remove it from gear a couple of time until i was slowing down.
checked the fluid level which was below the min, have had a look around the master cylinder couldnt see any leaks, havent had a chance to check slave yet.
FYI the clutch isnt sticking atall.
Wondering if anyone got any ideas ?
im going to bleed the lines tommorow so i can rule that out.
Cheers
Check the slave cylinder for leaks. They tend to leak around the rubber boot at the end. I went to change my clutch fluid as my clutch felt dodgy and the fluid was a bit dark and when I got underneath to bleed the fluid through I found the slave cylinder was leaking. Got it replaced with a new one, new fluid and braided clutch line and it's much better.
