Fitting Sound System
charlied
I had a similar problem with a different car so I fitted a universal ISO fitting behind the old connecter, and fitted the new head to that. Then make a fly lead with you old connector, It gives you the option to go back if you want to retain the head when you sell.
I know a little bit...
You need an Autoleads PC2-72-4
This part is the one also used in the Primera and Almera.
Im not sure that will fit, I got the Primera one, and there was no way it would fit, the Head unit has 3 connectors on the back of it !.
Your probably getting the Metra Harness from the states !
Steve
  • 5 months later...
i have a jdm model and have replaced the head unit and all the speakers
i used the wiring adaptor for the micra model with no problems .
the earth wire from the adaptor just needs earthing to the car body, when you remove the panels to change the head unit it uncovers a couple of bolts that you can use to conect the black wire to. :thumbs:
  • 3 weeks later...
