Blue smoke
timmytuck
Hi mate
I would say three days going very steady, the first problem was disconnecting those bloody plastic connectors, it took me the best part of a day trying to get the right angle to get the engine out.
After nearly giving up I found out one of the lifting straps had a grip on the gearbox :(.
I was so peed off once it was out I took the front panel off any way . You live and learn, I Have to thank you for you're threads it gave me inspiration
  • 4 weeks later...
Hmmm - could be a Cam position sensor or more likely the crank position sensor - they will bugger up your timing - a damaged flywheel "key" ring will do the same as will putting the flywheel on 180 degrees out of phase - which apparently you can do with a lightweight flywheel!
