Easty Posted December 18, 2013 Share Posted December 18, 2013 Sorted thanks :-) Quote Link to comment Share on other sites More sharing options...
Deklan Posted December 23, 2013 Share Posted December 23, 2013 These Banna's can be a pain! Easy change though! Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted January 3, 2014 Share Posted January 3, 2014 Would I be right in thinking you can just get the bush from h-dev now? Pretty sure after reading the descriptions on here that this is what my problem is Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted January 3, 2014 Share Posted January 3, 2014 We supply the genuine Nissan bush for £29.99 It can be found here http://www.clarkmotorsport.co.uk/parts/Compression-Rod-Bush/54570-AC70A Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted January 3, 2014 Share Posted January 3, 2014 Well that's a hell of a lot better than buying the entire arm Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted January 3, 2014 Share Posted January 3, 2014 Well that's a hell of a lot better than buying the entire arm Sent from my HTC One using Tapatalk Indeed its also advisable to change the seating cone which is £9.99 and the ball joint retaining nut at £5.09. All in stock. 1 Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted January 4, 2014 Share Posted January 4, 2014 I'll give you a shout when I've got some free money then Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted January 4, 2014 Share Posted January 4, 2014 No worries Quote Link to comment Share on other sites More sharing options...
Jixaman Posted January 7, 2014 Share Posted January 7, 2014 As well paying the extra for the arm, the ball is the same age as the bush, by the time you pay for the extraction / replacing (if you dont have access to a press) you wont be far off it and you may be visiting the same corner again soon anyway... Both sides on mine went within a year more or less of each other, at least if you replace the arm its done and not a worry for another few years... My take anyway... 1 Quote Link to comment Share on other sites More sharing options...
HARMLU Posted January 7, 2014 Share Posted January 7, 2014 Believe it or not, this thread has helped me with a problem in my daily, thanks Quote Link to comment Share on other sites More sharing options...
harryjackson Posted August 24, 2014 Share Posted August 24, 2014 I have had same problem since buying my car, changing the arm next weekend, lets hope that is the knocking problem! This post has made me feel a bit better about spending the cash to sort it out! Thank you Quote Link to comment Share on other sites More sharing options...
Zhorno Posted August 25, 2014 Share Posted August 25, 2014 If there is no excessive play from underneath am I wrong in thinking everyone is just changing them because they don't like the knocking sound , or isit because it's going to proply damage your car in not doing so Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jixaman Posted August 25, 2014 Share Posted August 25, 2014 If its knocking there is excessive play... Quote Link to comment Share on other sites More sharing options...
Lanky Posted January 22, 2015 Share Posted January 22, 2015 (edited) In case anyone is looking into the service manual, and this hasn't been declared already, "I-spy" a (non-)deliberate mistake in the Service manual diagram on P8 - regarding the compression rod. Before I fess up....a blue peter badge to who works it out right and gets it first!!! Edited January 22, 2015 by Lanky Quote Link to comment Share on other sites More sharing options...
JwBye19 Posted February 7, 2015 Share Posted February 7, 2015 I have a loud knocking noise coming from the offside, jacked up and found no problem, reading the posts sounds like a banana arm, is it likely to be just this? where is the cheapest place to get one? Can I do it 'on the drive way' so to speak? Would I need any specialist tools? Quote Link to comment Share on other sites More sharing options...
JwBye19 Posted February 7, 2015 Share Posted February 7, 2015 Also Is it likely to be the ball joint or could it be just the bushes or is it a good idea just to replace the whole assembly? Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted February 7, 2015 Share Posted February 7, 2015 (edited) Are any of the Traders on here able to source just the OE balljoint? There has to be a way of removing the old worn out one and replacing it with a new one, but unless new ones are available, there is no point in investigating this any further. Steve With no offence meant to the traders,I don't think they are bothered as long as replacement arms are available for then to supply or supply and fit.There are aftermarket arms available (quality unknown) for which balljoints have obviously been obtained from another source other than Nissan. With respect I do not think that is the case. The traders on here are very much bothered and we do our level best to serve you guys with quality products at huge savings and at times you have us jumping through hoops. I find your comments offensive and uncalled for So just to be clear: The ball joint for the compression rod is not available on its own and if this ball joint fails, then you have no option but to purchase a complete new compression rod. Alex. I find your reply quite offensive,and no offence was intended by me I can assure you. How much research have you put into the matter? If,for instance,an engineering firm could be found who would recondition the arms with a suitable balljoint sourced elsewhere at say £100 each for a bulk order and a trader could order a batch to be made and sell them at,say, £150 each then that indeed would be a better service.By far the the highest value in the item must be the alloy arm itself,and this bit is perfectly serviceable yet is thrown in the scrap bin at the moment. If you read my earlier post you would see that I had suggested as much but agreed that it might not be possible because such an exercise might cost out at more that the new arms anyway,in which case I would totally agree with you. ...and might I offer you some advice that it's not best business practice to get on your high horse unnecssarily with people like me who have already spent good money with you. If it's so easy speedwell why don't you do it ? ETA You come over as a bit of a tit TBH ... let me have your engineering qualifications and I might back your idea Edited February 7, 2015 by ATTAK Z 4 Quote Link to comment Share on other sites More sharing options...
JwBye19 Posted February 11, 2015 Share Posted February 11, 2015 Can anyone help? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted February 11, 2015 Share Posted February 11, 2015 Have the arm checked as per the service manual procedure, its the best way to tell whats worn Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted February 11, 2015 Share Posted February 11, 2015 Can anyone help? It appears to me that everyone is trying to help ... just bite the bullet and get a new B A N A N A B A R from a reputable source ... that will fix you problem 2 Quote Link to comment Share on other sites More sharing options...
JwBye19 Posted February 16, 2015 Share Posted February 16, 2015 Are the arms from JAP EURO CAR PARTS any good? They're £75, compared to a £250 gen nissan part Quote Link to comment Share on other sites More sharing options...
JwBye19 Posted February 16, 2015 Share Posted February 16, 2015 Will I need a banana arm cone or whatever it is? Quote Link to comment Share on other sites More sharing options...
RavenDW Posted April 22, 2015 Share Posted April 22, 2015 (edited) Well this is certainly an eye opening topic. I haven't had chance to take a good look at my new Zed but it does seem to rumble during urban driving. Investigation is required. I am, however, curious as to how the arms themselves 'fail'. If they're corroded or warped then sure. Or is it simply the bush and ball joint that go? Because surely the ball joint can be replaced (I've seen some for sale, but talk of replacing the whole arm makes me suspicious). But if the arms on my Z original then it's all coming up to being 8 years old so it's probably worth my time to put £500 aside (or less if I put my faith in eBay) and get the arms replaced rather than just doing the bushes and then having to be back underneath it in the future. It's going to have to wait until the summer when I have some holiday time and money Massive help from the forum as usual. Edited April 22, 2015 by RavenDW Quote Link to comment Share on other sites More sharing options...
RavenDW Posted April 22, 2015 Share Posted April 22, 2015 (edited) I'm dumb and quoted myself. See post above. Edited April 22, 2015 by RavenDW Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted April 24, 2015 Share Posted April 24, 2015 Well I've replaced both my bannana arms and drop links ad still have a knocking over bumps. Very annoying. There is also a knock if reversing and coming to a halt. It may be related. Quote Link to comment Share on other sites More sharing options...
