FooFighter Posted August 13, 2012 Share Posted August 13, 2012 I used to have slightly soggy squeeky suspension on my 05 plate Zed until I got new drop links and banana bar bushes from Alex about six months ago. That seemed to sort things out nicely (thanks Alex) but now I have a new suspension issue. The car feels like it is on slight camber (leaning towards the passenger side) even on flat ground and reacts more to awkward cambers on the road. I asked the garage to have look when my car was in for a service the other week and they couldn't find anything. They measured the suspension height and checked the bushes and say everything is fine. Something feels a bit wrong with the car though and I would welcome the wisdom of the Zed Club on what it might be. i may be imagining things but the steering also doesn't seem to feel as sharp as it did which may be related. My car has done about 50,000 miles. Many thanks Ed Quote Link to comment Share on other sites More sharing options...
Allan Zada Posted August 13, 2012 Share Posted August 13, 2012 did you get a wheel alignment after you changed the bushes? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 13, 2012 Share Posted August 13, 2012 Perhaps tyre pressures or tyre tread related. Alex Quote Link to comment Share on other sites More sharing options...
Neilp Posted August 13, 2012 Share Posted August 13, 2012 Perhaps tyre pressures or tyre tread related. Alex Was thinking that myself. What tyres are you using, hows the tread, hows the pressures? Quote Link to comment Share on other sites More sharing options...
FooFighter Posted August 13, 2012 Author Share Posted August 13, 2012 Thanks for the quick replies guys. I have checked my tyre pressures which are fine (35 psi all round). I have Bridgestones all round (the new ones, REO50's?) which still have around 4 to 5 mm of tread. I dont know whether my wheels were aligned when I got the bushes fitted by the garage (am a mechanical dunce) but I assume so because the car felt spot on for several months afterwards and has only recently gone off. Ed Quote Link to comment Share on other sites More sharing options...
bhavin85 Posted August 13, 2012 Share Posted August 13, 2012 Have you hit any big pot holes recently ? could have thrown the alignment out...or even damaged the rim ? Quote Link to comment Share on other sites More sharing options...
ewan221 Posted August 13, 2012 Share Posted August 13, 2012 what wheels so you have on ? Quote Link to comment Share on other sites More sharing options...
FooFighter Posted August 14, 2012 Author Share Posted August 14, 2012 Wheels are standard GT wheels (18 inch rims I think). I don't recall hitting any holes but it sounds like getting the alignment checked is a good idea. Quote Link to comment Share on other sites More sharing options...
ewan221 Posted August 14, 2012 Share Posted August 14, 2012 Not heard any stories abut rays but some alloys can be easily bent or damaged if driven over potholes or curbed, friend of mine thought he had suspension problems in his TVR turned out to be his front wheel being 50p shape. Quote Link to comment Share on other sites More sharing options...
DannyBoy Posted August 14, 2012 Share Posted August 14, 2012 Sounds silly, but how many speed bumps are there in your area? I live in a part of Surrey where the borough council are clearly in favour of rendering the roads unusable to anyone not in a large gas-guzzling chelsea tractor. As a result my suspension needs re-aligning every week or so (mild exeggeration). It's those ones that you're supposed to go one wheel either side of that do it i'm sure. DB Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 14, 2012 Share Posted August 14, 2012 A decent alignment would be a good start, see if that sheds any light on anything Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 14, 2012 Share Posted August 14, 2012 A decent alignment would be a good start, see if that sheds any light on anything +1 - an aboslute must I would have said after the work done Quote Link to comment Share on other sites More sharing options...
Dblock Posted August 14, 2012 Share Posted August 14, 2012 I'd personally get a free suspension check which some bigger garages do before it aligned Quote Link to comment Share on other sites More sharing options...
FooFighter Posted August 14, 2012 Author Share Posted August 14, 2012 Thanks for the replies guys. Am booked in for a suspension and alignment check later this week. Lots of speed bumps round here so that could be a factor. Will report back. Ed Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 14, 2012 Share Posted August 14, 2012 Not wanting to sound insensitive, but how heavy are you? You know, if everything on the car checks out..... Quote Link to comment Share on other sites More sharing options...
Darren-B Posted August 14, 2012 Share Posted August 14, 2012 Not wanting to sound insensitive, but how heavy are you? You know, if everything on the car checks out..... When I have my alignment done I always sit in the car as generally I don`t have passengers when pushing on so I have the car setup to compensate for my weight Quote Link to comment Share on other sites More sharing options...
FooFighter Posted August 15, 2012 Author Share Posted August 15, 2012 I don't think I'm that heavy Bulletmagnet! Quote Link to comment Share on other sites More sharing options...
FooFighter Posted August 19, 2012 Author Share Posted August 19, 2012 Update Had my alignment checked and adjusted on Friday and my car feels like it should again. Many thanks to everyone for your help. I had my alignment done at Autodynamics in Sheffield based on a recommendation on an old thread in the suspension section. I would recommend them too. Nice people who are very enthusiastic about what they do. Ed Quote Link to comment Share on other sites More sharing options...
