nickjon Posted August 10, 2012 Share Posted August 10, 2012 Hi Guys, I have a 2005 305z with 54000 miles on the clock. Im am experiencing problems with the clutch when the car is hot, the pedal gets lower and lower till it is hard to change gear. Its done this for a while now, wasn't a problem cause I dont drive too far but I have recently changed jobs and now need to go further. I have read it could be a problem with the fluid boiling due to heat from the exhaust and new stainless lines and fluid will sort it? Any advice would be appriciated. Thanks Quote Link to comment Share on other sites More sharing options...
Gball1973 Posted August 10, 2012 Share Posted August 10, 2012 Use the search function, there's been a few threads about similar problems but whatever you do don't take it to Nissan BTW, introductions here http://www.350z-uk.com/forum/viewforum.php?f=3 to the forum Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 10, 2012 Share Posted August 10, 2012 Hi Guys, I have a 2005 305z with 54000 miles on the clock. Im am experiencing problems with the clutch when the car is hot, the pedal gets lower and lower till it is hard to change gear. Its done this for a while now, wasn't a problem cause I dont drive too far but I have recently changed jobs and now need to go further. I have read it could be a problem with the fluid boiling due to heat from the exhaust and new stainless lines and fluid will sort it? Any advice would be appriciated. Thanks You will require a new slave cyl, braided line and fluid to fix this issue. All in stock and good to go same/next day viewtopic.php?f=157&t=57106 Drop me a PM if I can help you further Alex. Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted August 10, 2012 Share Posted August 10, 2012 I had this same issue. Got the parts from Alex and it's not happened since. Quote Link to comment Share on other sites More sharing options...
buzz62 Posted August 11, 2012 Share Posted August 11, 2012 i suffered this last night , this morning all is back to normal Quote Link to comment Share on other sites More sharing options...
