tez162003 Posted August 13, 2012 Author Share Posted August 13, 2012 Kicking myself.... Can anyone notice something about the calipers that means I cannot fit them too my car? I have spent a while fixing them up and never once noticed, I have so many times I had thought about it but didn't totally click. Quote Link to comment Share on other sites More sharing options...
sparky370z Posted August 13, 2012 Share Posted August 13, 2012 is it the pipework fouling on the inside of the alloy? or the connection for the brake hose? Quote Link to comment Share on other sites More sharing options...
Wasso Posted August 13, 2012 Share Posted August 13, 2012 Bracket too big?? Quote Link to comment Share on other sites More sharing options...
tez162003 Posted August 13, 2012 Author Share Posted August 13, 2012 Nope, the pipework will be fine i'm sure, i have 19s after all and they're only 355mm discs. Sort of has something to do with that brake hose connector. Quote Link to comment Share on other sites More sharing options...
tez162003 Posted August 13, 2012 Author Share Posted August 13, 2012 I've not actually tested the bracket yet. They are 350z brembo adapters so they should be fine. I'll wait for one more guess then i'll say Quote Link to comment Share on other sites More sharing options...
Jay Posted August 13, 2012 Share Posted August 13, 2012 Looks brilliant mate... good job Quote Link to comment Share on other sites More sharing options...
sparky370z Posted August 13, 2012 Share Posted August 13, 2012 lines too short? location of the connection on the caliper? Quote Link to comment Share on other sites More sharing options...
Wasso Posted August 13, 2012 Share Posted August 13, 2012 Here's standard Brembo's to compare with... Quote Link to comment Share on other sites More sharing options...
tez162003 Posted August 13, 2012 Author Share Posted August 13, 2012 Nope. So after many moments thinking about which piston goes where when fitted to the car (i.e. does the brake disc rotate onto the small or big piston first) i actually even said to myself oh wait doesn't matter, they don't look handed... Only late last night after I finished I went FU*K! I have 2 calipers for the same side of the car! The brakes are meant to be handed. I was thinking I dont really want to give this caliper back in return for the correct side in tatty condition, so rung the guy not knowing what the hell to do. He said it was his fault and is willing to just give me another caliper for the correct side and has no use for the one i painted. So a bit more paint and another Brembo sticker required, then swap the new bolts and pipe etc over (I will make sure my spare is as good as the other two, i will get the spare parts when I am near the shops, no rush there) After which I will have a rather elaborate paper weight... Quote Link to comment Share on other sites More sharing options...
sparky370z Posted August 13, 2012 Share Posted August 13, 2012 i didnt even know that they had different size pistons for the rotation of the disc. learn something new everyday!! Quote Link to comment Share on other sites More sharing options...
Wasso Posted August 13, 2012 Share Posted August 13, 2012 i didnt even know that they had different size pistons for the rotation of the disc. learn something new everyday!! Odd as the standard pistons on mine look the same size? Also your calipers don't look like they are from the same side?? The nipple is at the other end of the caliper just like oem Brembo?? Quote Link to comment Share on other sites More sharing options...
tez162003 Posted August 13, 2012 Author Share Posted August 13, 2012 That's the thing. I even had to think which side to fit the bleed nipples on, so i was looking at the pistons trying to work it all out OEM brakes have different sized pistons too, you can see from the picture above. The piston on the right that you can see in that picture above is bigger than the left. The disc should if I am right in saying should rotate onto the small piston first. I'm getting another caliper so its not a problem, in fact I will have a whole spare caliper now, but I am just kicking myself for not noticing before. Quote Link to comment Share on other sites More sharing options...
tez162003 Posted August 15, 2012 Author Share Posted August 15, 2012 So I went and got caliper no:3 just to realise when i got back that one of the bleed nipples was cross threaded. So back I go and got another one. Stripped it down, split it, wire wheel and sanded it, and is now ready for painting. Also got my disc bells back from the powder coater's. So i can now re build these. I was trying to find new set bolts for these, but they are hard to find for some reason. So I have sat and wire wheeled and polish wheeled all the bolt heads. I then realised I had only done 23 bolts and not 24 that there should be. I lost one... Hunted around the workshop for a good hour as I have a tenancy to just put things down in silly places. Admitted defeat and went home to find that one bolt sat next to the calipers... Not impressed. So, just the one caliper to refurbish now, new bolts bought, bleed nipples and copper lines I'll grab this lunch time. Then just clean up yet another brake hose, bracket etc. then I am there. Quote Link to comment Share on other sites More sharing options...
tez162003 Posted August 25, 2012 Author Share Posted August 25, 2012 Finally ready to fit them, new longer caliper bolts have been bought. Calipers finished and discs built. Quote Link to comment Share on other sites More sharing options...
KC350Z Posted August 25, 2012 Share Posted August 25, 2012 looks just need some pictures off them fitted Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted August 25, 2012 Share Posted August 25, 2012 top job Quote Link to comment Share on other sites More sharing options...
tez162003 Posted August 25, 2012 Author Share Posted August 25, 2012 will try fit them today Quote Link to comment Share on other sites More sharing options...
tez162003 Posted September 4, 2012 Author Share Posted September 4, 2012 So these brakes have been a nightmare. Since the last post, I fit them, tried bleeding them, got it good enough to drive, went round the block and upon arriving back the passenger side was billowing out smoke, one of the pistons was sticking. So I decided to do things properly. - All 4 brakes off - Completely striped, seals, bolts everything. - Sand blasted - Powder coated - Rebuilt with new fluid and dust seals, new bleed nipples etc etc Thought I'd get my spacers powder coated while i was at it. £30 for all the spacers and calipers to be powdered Fit them onto the car, bled them again. Pumped the brake a few times to pressurize the system, and some of the bleed nipples were leaking out the threads. Tightened them, still leaked, tightened a little more and one went pop. F**K! Luckily it was the caliper I had a spare of. Few talks with the experts has made me think it is the new bleed nipples. the OE ones are tapered with a slight flat bottom, the new ones were slightly longer, tapered with a flat bottom and a very very small nib on the end. I have swapped the bleed nipples back over to the old ones. Just need to try bleeding the system again. Hopefully this works, otherwise I may just give up. Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 4, 2012 Share Posted September 4, 2012 Hopefully it all works out. But don't give up your very nearly there Quote Link to comment Share on other sites More sharing options...
andlid Posted September 4, 2012 Share Posted September 4, 2012 sterling effort, don't give up you're at the end now! Will look class on the car with black wheels. Hopefully it'll make it stop proper! How did you manage to find them? Wouldn't mind trying something similar this winter to keep me doing something useful at the kitchen table Quote Link to comment Share on other sites More sharing options...
Daryl Posted September 4, 2012 Share Posted September 4, 2012 Amazing effort and patience,and im sure once they are all working as they should you will think it was worth it. Certainly look good on the car with the black wheels. Quote Link to comment Share on other sites More sharing options...
Siman350z Posted November 15, 2012 Share Posted November 15, 2012 Any updates? Amazing work, they look fantastic (and at £3k for brakes they ought to!) just hope you managed to get them working.. Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted November 15, 2012 Share Posted November 15, 2012 Loving this thread! Quote Link to comment Share on other sites More sharing options...
downhuman Posted November 15, 2012 Share Posted November 15, 2012 Looking awesome mate, keep it up. I had Alcon Racing brakes on the Racing Puma and they were a pig too....!! But amazing brakes Quote Link to comment Share on other sites More sharing options...
goodatcrashing Posted November 18, 2012 Share Posted November 18, 2012 The jobs you do to pass some time always end up being the most complex. Fantastic effort. Keep us updated. Quote Link to comment Share on other sites More sharing options...
